Question about NEC IT3510 Copier
How to replace laser in nec 3520 - NEC IT3510 Copier
I need a step by step instruction on how to replace ink cartridge for 3520 printer
go to hp and get a free users guide in there you will find out how to replace the ink cartridge
you will have to have your model number
Apr 19, 2013 | HP DeskJet 3520 InkJet Printer
Can i replace 1 Gb memory (for fujitsu amilo mini
your amilo 3520 can support up to 4gig memmory that would be 2x2gig
Oct 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Driver for HP Deskjet 3520
try to click at this link....use windows 2000
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=305968&lang=en&
May 26, 2009 | HP DeskJet 3520 InkJet Printer
Where do you get a refill cartridge for the NEC superscript 860
go to   www.precisionroller.com  they have everything and are a good company...
May 04, 2009 | NEC SuperScript 860 Laser Printer
Nec 860 laser printer fuser unit
remove cartridge and leave top door open, then remove two screws in back ; open front sheet panel to find two screws to remove then remove outer case carefully AND PLACE ON LEFT SIDE BECAUSE THERE'S A RIBBON WIRE ATTACHED.
there are 4 screws holding the fuser unit in place, remove AND LIFT OUT BY ROLLING TOWARD YOU to reveal 2 screws to access the red roller assembly!
In my case there was a very tightly wound piece of paper stuck in there not visable without removing the screws on the fuser unit!
Dec 18, 2008 | NEC SuperScript 860 Laser Printer
Prints what looks to be bar code
I have the same problem. I have replaced both toner and photoconductor, did not solve the problem. I have been using XP for some time before my printer started acting up.
Feb 21, 2008 | NEC SuperScript 870 Laser Printer
NEC SuperScript 860 Laser printer
In a word.... no. The NEC SuperScript 860 is a black and white laser printer. It does not print color.
Jan 23, 2008 | NEC SuperScript 860 Laser Printer
NEC SuperScript 1800 Laser driver to use for Windows Vista
Use the HP LaserJet 4 Driver. That's what I did and the printer works fine.
Nov 15, 2007 | NEC SuperScript 1800 Laser Printer
NEC IT3510 Copier Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
