Question about MSI RX480M2-IL Radeon Xpress 200 939p All-in-one PCIe16x M-A (7093040) Motherboard
How i can't connect my computer screen and VGA card when i already joined all cable connection ? please can u tell me anything for this problem.thanks
  • 428 Answers
There is a specific port for the vga and it has to be connected to the monitor, :) Its a blue colored one.
how i can't connect my computer screen and VGA - moz-screenshot-1.jpgd33076e.jpg
This is an example of SVGA.
It might be an on board vga or a seperate one. Find it. There is a special cable which comes from the monitor to connect it.
Please be kind enough to rate the answer :)
Good Luck TC
Posted on Jun 29, 2009
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
Jan 13, 2018 | HP Pavilion Elite M9000z PC Desktop
Asus led monitor model vh197 shows no signal on screen and no display ,screen became dark
Good Day Dasarathi!
Please check the VGA cable if its properly connected and make sure two screws are fixed to both end connecting the monitor and the video card.
No signal comes out when there is no signal from the video card to the monitor. That is why you need to check if the VGA cable is fix to both end.
If that did not fix it, you will need to open the casing of your computer. Disconnect the video card from the motherboard. Gently clean by wiping a clean clothe over the contact surface of the video card. Then, reseat the video card properly to the slot in the motherboard. Return the casing cover and connect the VGA cable again.
Just remember doing the above procedure is only when the computer is turn off.
Turn on your PC and see if that fix it.
You will need to replace the video card if by booting the PC you will hear a series of beep codes. If no beeps then you are lucky VGA cable is the faulty one.
Jun 09, 2011 | ASUS Computers & Internet
When connected to my Philips 47PFL7422 tv via HDMI cable I get video but no audio. When connected via the VGA port I get both audio and video,
The VGA cable is strictly just for video so the sound is received thru an analogue (RCA) cable. HDMI is an combined digital link but the video card delivers only the video - you must tell the tv from where to get the sound (use the analogue connection already in place) This is done in the menu.
Mar 20, 2011 | ASUS ATI RADEON HD 5450PCI EXPRESS21DDR3...
LG Studioworks 700S 17" CRT Monitor, on screen
Dear Sir,
This problem is not from monitor side,check computer RAM.Clean it twice and reinstall it on place.If you are using VGA card then disconnect it from PCI slots and connect VGA cable to on board VGA . I think it solves your problem.Let me know
Jan 08, 2011 | LG Studioworks 700S 17" CRT Monitor
Connecting wire between pc to tv
Depending on what type of TV you have, connecting your PC to your TV shouldn't be very expensive. Most newer models of TVs come with a VGA input.
Your computer has a cable to go to the computer screen, this cable is known a s a VGA cable, it looks like this:
Your TV might have a VGA input which looks like this:
All you have to do is unplug your VGA cable from your computer screen and plug it in to your TV so your cable will go fro your computer to your TV instead of your computer to your screen.
If your TV doesn't have a VGA input, it will have an RCA input which looks like this:
You can buy a VGA to RCA cable which will allow you to connect your computer to your TV which looks like this:
You can buy a VGA cable here:Click Here
You can buy a VGA to RCA cable here: Click Here
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Feb 19, 2010 | LG 22LH20 LCD TV
Dual Screens with a VGA connection
The easiest way would be to purchase a video card that has 2 vga ports on it, allowing dual monitor support. Here is an example.
http://www.amazon.com/Matrox-G450-16MB-Dual-Video/dp/B00194CT5A
Dec 29, 2009 | Samsung 2333SW 23" Widescreen DVI LCD...
Brand new Monitor blank screen says No Signal
There is nothing wrong with the monitor. The LCD is not recieving any signals from the PC. Either you are connecting the VGA cable incorrectly or your VGA card is not set from the PC BIOS. The VGA cable might also be faulty.
Recheck that all the connections are clean and secure. If you are using a PCI-E or AGP card, the computer BIOS should be set to send the video signals through the PCI-E or AGP card. Follow the procedure in your motherboard manual.
If your pc has on-board graphics then you should connect the VGA cable to the on-board VGA out connector.
Oct 19, 2009 | Acer X203H bd Monitor
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Can't Turn On?
check you vga cable and resolution of vga card
Apr 21, 2009 | Computers & Internet
MSI RX480M2-IL Radeon Xpress 200 939p All-in-one PCIe16x M-A (7093040) Motherboard Logo
76 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
