Question about Epson Stylus CX4800 All-In-One InkJet Printer
How do you clean the heads on a dx 4050 - Epson Stylus CX4800 All-In-One InkJet Printer
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
R E A D T H E M A N U A L
Posted on Jun 29, 2009
Canon ipf 750 e161-4050
The error refers to a purge motor failure. Which could explain why the printer is saying that you do not have enough ink. You can solve this error code by removing the purge unit. You have to replace the purge unit with a new one.
Read more: E161-4050 on iPF750. error not in manual. Cleaned print head? - What is this? Not on internet anywhere. I`m sure others have had this issue. :: Ask Me Fast at
Jan 11, 2013 | Canon iPF700 InkJet Printer
Dx 4050 changed all ink cartridges lights still flashing
try shaking the cartridge before inserting it into the printer s35
Sep 21, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error code E01 stands for?
Basis Steps For All Printer. ( Ink jet or Laser jet )
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 25, 2011 | HP 4050: HP 4050 laserjet printer , 8MB...
Paper wont feed
Make sure that the printer track is free of any torn paper. Make sure that the tractor feeds themselves are free from debris. Turn it off during this check.
Apr 24, 2009 | Office Equipment & Supplies
NEED Hi8 head cleaning tape
Best Buy sells one.
Dynex® - 8mm Head Cleaner Model: DX-DA100511 | SKU: 6997315 Here is the link. http://www.bestbuy.com/site/olspage.jsp?skuId=6997315&type=product&id=1099391463958&ref=06&loc=01&ci_src=14110944&ci_sku=6997315 Just "google" hi8 cleaner tape or 8mm cleaner tape and you will find many, many places to buy one.
Jan 21, 2009 | Sony Hi8 Cleaning Cassette / Head Cleaner...
I have an HP LaserJet 4050 and it needs perform printer maintenance. what should i do
it means it is time to do some preventive maintenance on your unit, or keeping the print heads clean
It is important you keep the printer heads clean. This stops ink clogging the nozzles of the printer, and reduces ink smudge on the paper. This is important for HP , as they don’t always do the best automatic clean in my experience.
To clean the print heads, remove the cartridge, and gently clean the print heads with a soft cotton cloth dipped in a little water. I wouldn’t recommend using tissue or alcohol. Be warned!
Make sure the print heads are dry and then replace the cartridge. By doing this you will expand your printer life and the quality of the printouts.
Prevent the printer from drying up ink by using it
I remember taking support calls around a year ago. People would say I haven’t used the printer for over a year, and the quality isn’t what I expected.
If you use your printer regular this will prevent ink drying up and keep the printer and ink in good condition. Use both Colour and black and white prints weekly to stop the nozzles on your printer getting clogged up, or the ink to simply dry up. Be careful with printer jams Don’t ram the paper out if you have a paper jam. This can damage the printer, which I have seen done many times. Look at guides on the manufactures site, if you don’t have time to do that, remember that you want to get the paper out smoothly. Most HP Printers have a hatch attached at the back that can be removed. You will then have access to the paper wheels, and you should be able to see the paper that is jammed in there. Remove the paper this way, and it is unlikely that you will damage the printer. Power down correctly Turn your printer off when not in use. This can prevent drying of ink and also help keep the printer functioning at high quality. Remember to use the printers power button, and them remove at the plug if need be. Don’t power off if you are in the middle of something. These will just cause problems for you. Clean your printer but don’t over do it IF you perform print ink clean by software or your printer’s hardware, do it once and not over and over. Doing this over and over can cause more damage than good. Clean your printer’s encoder strip monthly to stop quality issues at a later date. Remember if you have low ink to replace immediately. This prevents ink being left in the printer heads and nozzles, and will generally give your printer more life.
hope this helps you, dont forget to mark my solution pls.
Aug 08, 2008 | HP Office Equipment & Supplies
DX stylus 4050
CLick on this site
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Download the proper driver to your desktop, when the install asks you for a driver location, click bworse and select the driver and do an auto install.
Should be quick and fairly easy.
Mar 28, 2008 | Epson Stylus Photo R320 InkJet Printer
Dx 4050 printer
Download the driver you require form the Epson web site. remove the existing driver before you install the new one.
Jan 07, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson dx4050
You'll have to completely disassemble the printer and get the printhead out.  Not an easy job, and lots of tiny parts involved.
Oct 27, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
