Question about Kodak EASYSHARE M763 Digital Camera
When i turn my kodak camera, 7.2 pixels,on the lens comes out and goes back in and shuts down. I charged it all night and still happens. HELP! Less than a yr. old
    President:
  • 2,761 Answers
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
  • Bill Buchsbaum
    Bill Buchsbaum Aug 16, 2009
    This problem is frequently due to either weak/worn out batteries or corroded battery terminals inside the
    camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth
    (heavy corrosion may require a fine wire brush, steel wool, or
    sandpaper). Remove any residue left in the camera by the cleaning.
    Clean the terminals on the batteries in the same manner, and then
    replace them in the camera. This cures most problems, but if it
    doesn't work for you, check the Kodak troubleshooting guide at:
    http://www.kodak.com/global/en/service/r...
    It uses a simple Q&A format to diagnose problems and propose solutions.
When I turn the camera on, the lens goes out then back in. I have charged it all night. Any ideas? Think I need a new battery? I have a kodak 3x optical zoom 7.2. Of course I am on vacation while this...
Does the camera show battery empty? If yes, this is the problem and it could be solved with a new battery.
Anyway, the best thing you could do is go to a Kodak dealer and ask they're help, as it might be a software problem too.
Apr 06, 2010 | Kodak EASYSHARE M763 Digital Camera
Kodak M314 Problems
Only a week old?...take it back.
Mar 12, 2010 | Cameras
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
Camera turns on, blurry screen for a second, then turns off.
There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly.
An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 07, 2010 | Kodak Z8612 Digital Camera
My camera shuts off when I my zoom is nearly halfway through
Make sure your batter is fully charged, and is not bad. This kind of reaction can happen with a weak battery or partly charged.
If that is not it, then the camera needs repair.
Sep 27, 2009 | Kodak EasyShare V1073 Digital Camera
My camera turns on then turns back off right away!
Hi Most proberly the batery is shot. It wil be fully charged but it does not have "the amps" in this case miliamps to do the job. Pushing out the lens uses alot of the amps "miliamps" and the fact that it can't even rectract the lens back is a sure sign. If possible take the camera to a digital shop and test it with a known good batery!
Strongs
Aug 16, 2009 | Kodak EasyShare M863 Digital Camera
My battery is fully charged, camera goes on and shuts off.
this generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
Jul 15, 2009 | Kodak EASYSHARE V1253 Digital Camera
My camera turns on and then right back off. wen u press the power bottom the screen comes on and shows the Kodak label like its turning on and the lense begins to open but immideatly closes and the camera...
I had the same problem. This is how I fixed mine! Turn on camera grab the lens with two fingers before it can re-tract back into the camera and shut it self down. Use compressed air around the lens housing no more the 80 PSI. Hopefully this will remove any dirt.
It worked for me!
Jul 13, 2009 | Kodak EASYSHARE M1063 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera dead
If in the UK, this will be covered by the warranty return it to Kodak for repair,
May 10, 2008 | Panasonic D-Snap SV-AV100 Digital Camera
Kodak EASYSHARE M763 Digital Camera Logo
170 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
