Question about Elo 15" Touch Monitor
ELO model ET1515L, I need the power tranformer.
ELO model ET1515L, I need the power transformer.
Touchscreen display elo flickering
Turn down the brightness on the monitor, if it works it will be a short term fix, the problem is in the inverter transformer or capacitors in the power supply board.
Apr 03, 2012 | Tyco Electronics ELO Parts Touchscreen...
How easy is it to replace an intermatic ML300RTW malibu tranformer?
Question is not 100% clear.
Add a comment any time, and that sends email, and I will respond with more information if needed.
1) Are you trying to repair a transformer?
I do not know of any repair for the transformer, or available parts sold to repair transformer, although the product does have a warranty, and Intermatic might have a repair protocol for the transformer.
http://www.intermatic.com/customer%20service.aspx
2) Are you replacing existing transformer with a new transformer?
The transformer plugs directly into outdoor outlet, and wires are connected to A and B terminals.
Open following link to read how to set up and use transformer in troubleshoot-format:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Sep 17, 2011 | Intermatic Malibu 300W Power Pack...
Audio video control centre. digatal delayed surronds,model no str-d350z was plugged into wrong voltage,part burned out,can you help
You have not specified the make/model. But if you set is having the transformer as the case may be, and you have plugged into the 220volt with the 120 volt settting, then the transformer would have burned off. If so identify the secondary voltage of the DC cicuit and use a 220volt transformer to replace. If you are not able to identify multiple tappings then you must get the primary of the burned tranformer wound for 220volts. If at all this is aSMPS unit then you will need to replace the full unit as the ratings inthe power will be different.Since you have not specified details of voltage and ratings,I am not able to advice more. Hope you decide. Good day
Jul 23, 2010 | Sony Electronics - Others
Need power cord tranformer for my computer speaker system. plug on one end other end 3 pin system on othe Transforms 110v down to I guess 12v. not sure
you'll need electrical specs of the transformer (current and polarity) for the speaker system and mechanical connector spec. At the very least a model and number.
Mar 21, 2010 | Audio Players & Recorders
I have the 600-water Malibu transformer. Some nights one of the loops of lights will go out. The other loop stays lit. I might go out 30 minutes later and both loops are lit. I am still well under the...
Check for a loose connection where the problem "loop" connects at the tranformer.
Also, swap the "loop" connections to the tranformer. If the problem still persists replace the wire run. Sometimes wire gets damaged internally and visual inspection will not reveal that.
If the problem occurs in the other loop after the swap, then you probably have a bad connection inside the transformer. If that is the case, you won't be able to use that connection as the transformer has no user servicable parts.
Also, if the tranformer in under 5 years old, it's still under warranty.
Jul 06, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
Logitek transformer for force 3D
The power supply is Logitech Model # GAD-SLU-240A8 P/N 190057-1000 OUTPUT IS 24V-----0.75A The output connector is positive center, negative outer ring.
Oct 02, 2008 | Logitech WingMan Force 3D Joystick
Computers & Internet Logo
331 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
shahid_ptv
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
