Question about Sony Mavica MVC-CD400 Digital Camera
Power button problem
I think someone plugged the AC charger into the wrong plug (possibly the acc). Now to turn off the camera, I need to take out the battery. Does anyone have an idea how expensive of a problem this is?
    President:
  • 4,402 Answers
The ac charger wont fit in the acc. , more likely the power switch is broke, if you send it in to sony they can tell you the cost of repair.
Posted on Jan 08, 2008
Mu tablet froze when i went to turn off
Ive experienced this & someone suggested I plug in my charger/ac adapter. Sometimes it will react to the ac power current. If not you may have to use the 'expanded paperclip' method look for a pinhole size port that may be marked 'reset' (and possibly unmarked) straighten out a small paperclip carefully insert end of it into the hole. I've had to use both methods on my devices and theyve always worked. I have a Nextbook Tablet that freezes so often on shutdown that I keep a paperclip in its cover! Yet another tablet I HAD doesnt have a reset pinhole. I hope this will help you.
Jan 17, 2015 | Google Android Www.gadgetgiants.com...
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Ac keeps shutting
Remove the battery and plug in the AC adapter. If you can not power on the laptop, your AC adapter has gone bad on you and will need to be replaced.
If it will turn on with the AC adapter, place the battery while the laptop is on. See if it registers the battery as charging in the task bar. If not, there may be something wrong with the battery or the components connecting to the battery within the laptop.
Also you can below steps to check:
1) take the battery out of your laptop and the laptop charger
2) plug your laptop charger in your laptop without the battery in it,
3) Try to turn it on the normal way:
If it turns on, then your battery has gone, (Its drained and run out of use like all batteries do)
if it stays off then its a charger problem
You would want to hope its a charger problem as they are cheap and easily replaceable
Hope i helped
I guess its a charger problem because its not turning on and the laptop automatically would use the charger as a main power supply if the battery doesn't work
and oh by the way
If the battery isn't in it, your laptop will act as a pc whereas if you plug the charger in it will work, but if you take it out while the laptop is on then it will go off instantly without a successful shutdown which could mean a loss of work
Regards,
Rahul
Jul 14, 2013 | Compaq Presario CQ62-112TU
Xps 17 battery charger
I think either you have the wrong DC Power Jack installed (where the power cord plugs into the computer) or the wrong AC Adapter & Power Cord.
Hopefully you have an AC Adapter Power Cord that was made for your computer and not one of those one size fits all that some stores sell with the interchangeable tip at the end that plugs into the computer.
Mar 30, 2012 | Dell Xps 17 Laptop Computer (Intel Core i7...
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Dec 28, 2010 | Computers & Internet
Kodak digital camera not charging/ indicator not shown while plug in charger
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
Jun 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
Hi i have Toshiba a500-15m i used the ctrl -Alt -
Its not in sleep mode. The battery has run out completely. You said the charger is plugged in but does not show at the frond led.... which means something is wrong with the charger. First try a different plug, may be the fuse for that plug is blown or something. If problem persists check if the connection is loose where the adapter meets the wire. I ve marked that section within the red circle.
If the problem continues to persist you might have to buy a new AC adapter for your PC. Before you buy a new one, try using someone else's adapter who owns a Toshiba Laptop. Do not use it for a long time though since it wont be the recommended adpater for your laptop model.
If none of the above help, the laptop's plug in itself must have gone bad. You can get that checked from Best Buy etc. Let me know how it goes.
Apr 02, 2010 | Computers & Internet
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Help! Laptop is dead, no power
1.have you charged the battery long enough?
2.is your charger working?
alternatively it is possible that your charger pin is not receiving power supply. you will need to get it checkd.
Apr 15, 2009 | Acer TravelMate 3260-4874 Notebook
Sony Mavica MVC-CD400 Digital Camera Logo
42 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
