Question about Kicker KX300.4 Car Audio Amplifier
Hi i own a kicker kx300.4 and i don't have a manual to check the trouble shoot but my protection light won't shut off so i can't get any power to the amp any suggestions
  • newwithtech Jun 29, 2009
    any one out there that can solve the kicker problem
  • 113 Answers
You probably have internal damage to resistors and caps maybe even mosfets. Or you have power and ground reversed
Posted on Jul 04, 2009
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
I have wired up my kicker ds 65 (two of them) they were playing now they don't ..what's wrong with them??
Does your amplifier power light come on? Is the amplifier Protect light on? If the Protect light is on, there is either a shorted wire or an internal fault with the amp. Else check your wires inside and outside the sub box/speaker box and check for resistance across your sub terminals to check for blown subs/speakers.
Oct 01, 2011 | 2001 Honda Civic
Problem with Eathquake amp 2000w
the amp dose not have any such internal batery it is probly tosted call me 256-698-9903
Jul 05, 2010 | Earthquake Sound PH-D2 Car Audio Amplifier
It plays for a couple of seconds and then runs over to protect mode and stays there
usualy means there is a problem with the speakers, they may be wired wrong, short in the wires or the voice coil in the speakers themselves. best way to trouble shoot is to power the amp with no speakers hooked to it, if it only goes ito protect with the speakers hooked to it, the the problem is with the speakers, not the amp.
Aug 17, 2009 | Kicker KX400.1 Car Audio Amplifier
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Kicker protection light won't shut off
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Jun 29, 2009 | Kicker KX300.4 Car Audio Amplifier
Capacitor shuts off
HI DUDE UR CAR BAT NEED TO B CHANGE PLUS UR ALTERNATOR IS GOING TO FAIL SOON ... THATS ALL ... IF U ARE USING NOW IT MAYBE COZ LOTS OF PROBLEM TO CAPICATOR
Apr 05, 2009 | Kicker DX700 Car Audio Amplifier
Protection light is on
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 26, 2007 | Kicker KX600.1 Car Audio Amplifier
Kicker KX300.4 Car Audio Amplifier Logo
189 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
