Question about OKI MICROLINE 320 Turbo Matrix Printer
After hours it will print the alphabet and numbers by itself
After hours it will print the alphabet and numbers 1 full line per page including symbols, how do i fix this?
  • 22 Answers
This sounds like a test print. Are the membrane switches torn or depressed on the front panel? If you hold down LF or FF as you turn on the printer, you will get this same test pattern printed. You can also try reseating the connection between the front panel to the logic board along the left front corner of the printer.
Posted on Jun 29, 2009
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
I have two or three lines per page on my Officejet Pro L7780 that do not print the full letters on the line. Ink is full, but the two or three lines on each page do not print fully.
remove the printer heads and just dip the bottom in some hot water for about 20secs. (JUST THE BOTTOM)This should unblock the ink . Dry and iput back into printer
Apr 13, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
I want to have the source codes for printing diamond shape asterisk in visual basic
I am pretty sure I got this as a homework assignment in programming class. If I had someone give it to me then I wouldn't be even the limited programmer I am now. That said, I will help, but I will not give you the full out answer.
  1. The number of stars and characters per line are an odd number to make the ASCii look like a diamond. For my example, the maximum number of characters per line is five.
  2. Create a variable called dia_star that will hold the spaces and stars. To figure out the number of spaces that should be put into each star line, use this formula:
number of spaces per star = ( max number of characters per line - number of stars) / 2
dia star = number of lines before star and "*"
print dia star
  1. --*--
  2. -***-
  3. *****
Good Luck,
NOLA Tech
Jan 30, 2010 | Microsoft Visual Basic Enterprise Edition...
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
Changes from 1 to 3 pages for Excel Print Area
verify the page dimension in your driver together with the header and footer dimensions
Mar 11, 2009 | Zebra GK420 Thermal Printer
TALLY T2250 PRINTER
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
HP Dekjet 5650, 3 problems
1. The Page that it is trying to print is an automatic alignment page that prints when new cartridges are installed. If it does not print successfully it will try and reprint it. You need to let it print at least once successfully.
2. What kind of cartridges are you using? Are you replacing both cartridges or or just one of them? I will bet 100% that this problem is the cartridges! And that the first problem will also be solved by getting new Cartridges in the printer. I have seen Many times where Cartridge after Cartridge have failed. Or the user is only replacing one of them, and still getting the problem.
3. An easy fix to this is both those options are available on the printer itself and you can access them with the front panel. Usually they can be found in the menu under tools.
Jan 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
OKI MICROLINE 320 Turbo Matrix Printer Logo
170 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
