Music downloaded as WMA from PC to MP3tech MP3S4 wont play
Music downloaded as WMA from PC to MP3tech MP3S4 player shows as 'file error' when I try to play it but plays OK on PC when I feed it back into PC via USB.
  • 22 Answers
Your player should support both MP3 and WMA files. What happens when you try to play an MP3 instead? Have you tried other bit-rates? Those you are trying may be too high or low.
Posted on Jun 29, 2009
My mp3 says file format error when I try to listen to the music.
It's possible that the file type of the music file(s) you are trying to listen to are not a supported format of your mp3 player. Your player only supports MP3 and WMA audio formats. You should check the music files you are tying to play to confirm they are of a compatible format.
http://www.cobyusa.com/files/manuals/MP300_MN.pdf
Mar 02, 2011 | Coby MP300 MP3 Player
Download from audible
hi,
Have you tried connecting to the net and then continue to subscribe??
Feb 09, 2008 | SanDisk Sansa Clip MP3 Player
Wont play music
I took all the music out of folders on the device and just had the songs on the device without being in a folder and it works fine.
Jan 07, 2010 | Sears GC-822 MP3 Player
MY SANSA WONT SYNC SONGS..
The songs are in the wrong format - they need to be stripped of their DRM license (illegal) or converted to mp3 format.  The best, most legal way to do this is to redownload the songs as an Mp3 file, or re-rip your CD's in Windows Media Player in Mp3 format.
these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC (iTunes), WAV, RA, etc.  In addition, every file format type is in a certain bitrate, size, etc.  By far the most common issue is that the music file contains a license or copyright (especially with WMA or AAC file formats).  Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.   If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu.
Mp3 player product documentation is not straightforward.  If a player supports only non-protected WMA files, it will merely say that it supports WMA – it will not tell which type of WMA it supports.  A player that supports DRM-protected WMA’s will usually indicate such on the box (usually with a Windows Plays For Sure logo – which is actually an ironic misnomer).  DRM stands for Digital Rights Management, and it is a type of licensing system for WMA files.  It is used extensively by mp3 player music services such as Bearshare, LeapFrog, Napster, and others.  Not all DRM licenses are created equal – there are licenses with “play rights,” burn rights,” and “transfer rights.”  Play rights mean that you can only play the song on your PC – it will play fine on your computer, but it will not play in your mp3 player even though it appears to transfer.  Burn rights mean that the song can be burned to CD.  Transfer rights mean that the song can be transferred onto an mp3 player that supports DRM-protected files.  Then, there are unlimited licenses and limited licenses.  Limited licenses only allow you to play a song for a certain length of time. You would have to pay extra to continue using the song after that trial period is over – the time length ranges from a few days to several months or longer.
-Tha Mp3 Doctor
Sep 12, 2008 | SanDisk Sansa e260 MP3 Player
Transferring Audio Filles
The songs are perhaps in the wrong format.  This player will not accept copy-protected iTunes (AAC) files.  Also, the license on your files may not permit transfer to mp3 players. Definitely check the bitrates on your files, b/c this Sony can only accept certain ranges of bit rate.
This is my general spiel about music formats, but note that your Sony does accept DRM-protected files with transfer rights, so not everything in the following blurb applies fully to you: All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC (iTunes), WAV, RA, etc.  In addition, every file format type is in a certain bitrate, size, etc.  By far the most common issue is that the music file contains a license or copyright (especially with WMA or AAC file formats).  Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.   If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu.
-Tha Mp3 Doctor
Sep 09, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
I can't download music from my computer to my InVion 256MB MP3/WMA/REC. Do I need something special? Computer says it recognizes new hardware but I have'nt been able to download music
Are you getting a specific error message when you try to transfer songs? Does it look like they are transferrring, and then do not play? Are you just looking for the program that you would use to transfer songs? I would suggest Windows Media Player. Is iTunes your music service? If so, they will not work with this mp3 player.
You can also drag and drop the Mp3 or WMA files from Windows Explorer:
Try this - connect your mp3 player to computer --> double-click on My Computer --> double-click on the icon of the mps player --> double-click on the music folder --> drag and drop the music files to a folder/desktop of your own choosing
Check the format of the song - this player will play mp3 or wma, but if your wma's do not have "transfer rights" then you cannot transfer them to this or any other player.
-Tha Mp3 Doctor
May 28, 2008 | Audio Players & Recorders
My files wont play
Spiralfrog uses microsoft plays for sure drm protection.
Spiralfrog downloads will play on these mp3 players.
When your player is not supported you should find another
download site as drm sucks big time :)
Jan 12, 2008 | Audio Players & Recorders
File error
What's the music format of the songs that you placed on your mp3 player? Some MP3 Players only capable of playing song files with .mp3 extension and are incapable of playing other music format like wav, wma, etc. Check also the contents of the player for corrupted files and foreign files. Some viruses from a computer could affect the performance of your mp3 player.
Jan 02, 2008 | Sony NWZ-B103FBLK MP3 Player
Yepo digital audio player
hi i can not transfer files to my yepo mp3 it says my comp dosnt support it i have windows vista loaded the manual says i must convert ACT to WAV format could you please tell me how to
thanks
Nov 09, 2007 | Audio Players & Recorders
Won't paly WMA files that I bought online!
I remember reading somewhere that if you upgrade your firmware of your H340 from US to international to get video you lose the ability to play DRM music. I from this I would that the international version can't play the copy protected files. I am not sure of the legalities in your location, but you may be able to work around the copy protection. Maybe a google search would give you some hints.
Nov 13, 2006 | iRiver H340 MP3 Player
69 people viewed this question
 Grubhead
Grubhead
