Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 BLUE SCREEN NO PICTURE NO SOUND
My Mitsubishi WD-62525 just stopped working, it has no sound and a blue screen with lighter cloudy blue lines through the center, when I use the device menu to try to switch it to a component it will come up and when I change to another component the screen goes a back dark green with white dots. I am not sure if it is the lamp or what it could be, please help!
    Problem Solver:
  • 9 Answers
I had the same problem and I found that it was 2 caps on the power supply board. I had both caps replaced and it worked perfect. While it is apart see if any other caps are bad( if they are puffed up in the center they are bad).
Posted on Jul 19, 2009
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
The sound works. The screen is black when the
It sounds like the Chassis needs to be sent to Mitsubishi for refurbishing. The Boards are not available and have not been for quite a while.
I recommend you to call Mitsubishi at 1800-332-2119 to see if they would help you in the cost of repairs due to the costly nature of them. They would also refer a Service Facility
near you to do the work. I would estimate a repair cost of 300.00 or so if they help with the repair cost. If they don't, I estimate a cost of 700.00 to 800.00.
I hope this helps,
SkyAssoc
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blue clouds in the screen of a Mitsubishi WD-62527
i have had similar problems before for me it was caused by a strong magnet on the floor below me. i suggest looking around for a strong magnet that could cause the problem
Jun 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Somehow you have your inputs not on... but don't get ahead of ourselves. Check the cables in back... The video cable in... make sure it is fully connected from cable box / satellite box to input, then make sure the input is on where it is plugged in.
Feb 18, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Blue screen with white snowy circle in the middle of screen
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Oct 20, 2007 | Mitsubishi WD-62525 62" Rear Projection...
No signal, blue screen
If no video and OSD is good then: Suspect the Signal PCB part # 930B923002
Sep 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
586 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
