Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Reset sharp aquos tv - Sharp Aquos LC-42D62U 42 in. LCD HDTV
SOURCE:
SOURCE: i dont remember my secret
---How to reset secret number---
Press Menu using the remote
Select Parental Ctrl using the remote
PRESS AND HOLD BOTH CH^ and VOL+ AT THE SAME TIME UNTIL THE MESSAGE APPEARS ON THE SCREEN
Posted on Nov 30, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
  • 597 Answers
SOURCE: my sharp aquos not working tv went off and wont
these flashing lights are error codes set by the manufacturer..
Call sharp...they will tell you the problem
Posted on Apr 26, 2010
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
bugoy31
  • 1238 Answers
SOURCE: 60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Posted on Dec 19, 2011
How to reset a sharp aquos?
Hold VOLUME UP and CHANNEL UP buttons in while plugging set into power.
TV comes up in service mode.
Press CHAN + or CHAN - to select an adjustment that you want to change
Press VOL+ or VOL- to adjust
Jul 22, 2014 | Sharp AQUOS 65" 1080P Roku Ready LED 120Hz...
Lost the remote for my sharp tv. And the control panel is locked. Who do I unlock the control panel with out the remote?
If the problem you are having is that the television's operation lock out for the buttons on the tv has been enabled then the only way to undo that is with the Sharp remote control. The only work around I can think of is to perform an INIT, which is a factory reset. I do not know is Sharp customer service will still walk you through that over the phone because it is a detailed and dangerous (in that it can wipe the memory of your television if done improperly) process. I do not know what type of Sharp you have i.e. aquos or non aquos. 800-BESHARP is the number for non aquos support and 877-332-7867 is the number for aquos support (open 24 hours for aquos support last I checked)---32 inch and over aquos that is.
Aug 20, 2011 | Televison & Video
Is there a reset button on the 27 inch sharp aqua tv?
  • Press "Menu" on the TV's remote control and use the arrow keys to scroll to "Setup."
  • Scroll down to "Reset" and press "Enter" on the remote.
  • Select "Yes" using the arrow and "Enter" buttons at the "Return To The Factory Preset Values" message.
  • Select "Yes" using the arrow and "Enter" buttons at the "Now, TV Will Restart Automatically. OK?" message.
  • Wait while "Now Initializing..." appears on the screen. The TV will power down and turn back on when the reset is complete.
  • Read more: How to Reset a Sharp Aquos ' eHow.com http://www.ehow.com/how_7225301_reset-sharp-aquos.html#ixzz12i633RwM
    Oct 18, 2010 | Sharp Televison & Video
    Sharp aquos no sound through hdmi
    Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
    Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
    Sharp Aquos 32 wont turn on
    I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
    They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
    I doubt Sharp's policy alot less now!
    Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
    I dont remember my secret number of my tv lcd sharp aquos 52 inches and i dont know how to reset?
    Nov 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
    Freeview channels (DTV) on a Sharp Aquos TV
    On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
    can anyone help
    Nov 22, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
    Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
    Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
    651 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
