Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
Convert from natural gas to propane
Can anyone help me to convert this stove. I have the 4 pieces to change in the burner but is there an order they go in
  • billyonghui May 22, 2008
    I have a GE XL44 Profile gas range I want to convert from Propane to natural gas. I get the jist of these instructions and I have the natural gas orifices, BUT:
    1) How do I get at the orifices in the stove that I have to change?
    2) Where is the regulartor in which I have to turn around the "plastic part"?
    3) What do I look for when adjusting the gas flow into the oven?
  • 473 Answers
Step 6:
To prepare the new unit for LP gas you need to adjust several items. First you will need to replace the range orifices or spuds. These are individually sized with marks and colors.
convert from natural gas to propane - remove_spud-s.jpg Step 7:
Using a nut driver, loosen the old spud and replace with the new one.The trick to keeping from dropping the spud down inside the range is to use a small piece of aluminum foil between the driver and the spud. This should provide enough "grip".
If you do drop one down inside, you'll need torx wrenches to disassemble the burner units and get inside.
orafice_setting-s.jpg Step 8:
tighten_orifica_on_broiler-s.jpgThe oven orifices need to be adjusted. Using an open-end wrench, tighten down the brass fitting on the oven burner valve.
Step 9:
There may be two orifices, one for the broiler and one for thconvert from natural gas to propane - reverse_for_lp.2.jpg
reverse_for_lp.2.jpg Step 10:
You will need to reverse the plastic pin in the regulator underneath the range. Remove the hex nut and flip the plastic pin and reassemble the nut.
Do not over tighten!
The last step is to open the air shutters on each burner as per directions included with the range conversion kit.
Posted on Nov 07, 2007
  • Craig Shelton
    Craig Shelton Nov 07, 2007
    Also, The orifices are stamped with a number that determines there size. The smallest # goes to the smallest burner, Largest # to largest burner and so on.
  • Craig12345 Aug 01, 2011
    Does this hold true (Plastic pin) on a GE Hotpoint Model Number RGB790BEK5BB?
Changing stove from gas to lp do we need to open top of stove to do this?
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Sep 12, 2010 | Ovens
Stove burners will not light
I went directly to GE's website and found the diagrams for my stove with the parts listed. Thats what I needed !
Thank you,
Jun 29, 2009 | GE Kitchen Ranges
Stove burners won't ignoite
remove a burner cover and while observing the burner turn on the ignitor listen to it click for that burner ; you should see a tiny lightning bolt like flash if you do not tun off the burner clean the area and, try again oil and grease coat the burner gas plate and isolates the ground that the spark needs to be able to "jump" to
Apr 26, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Glass stove top has a piece that has peeled back
once they are broken they are broken you have to replace he whole top
Feb 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Because of the difference in energy between the two gases, the regulator is not all that needs changing.
I'm not sure which 'nozzles' you have but essentially all of the jets' one at each burner, at least one in the oven; probably two if your have a broiler element, need to be replaced.
It isn't a hard job but I suggest you speak to the manufacturer about re-jetting and where to order the parts you need.
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to:
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Natural Gas to LP Gas
you will need to change the orphis in all 4 burners,and flip the cap on your regulator.depending on your model the oven might be converted by screwing the orphis down
Mar 29, 2008 | Kitchen Ranges
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
390 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
