Question about Kettler Ergo Racer GT Indoor Cycling Bike
Hi, I have a problem with my Kettler Ergo Racer. I replaced the drive belt and had to remove a number of components to fit the belt. On re-assembly the bike does not increase resistance when I increase the power rating on the display. Any thoughts on what I may have done wrong in re-assembly would be appreciated. All looks OK, no wires hanging off or anything like that. Thanks in advance Barry
    Problem Solver:
  • 7 Answers
I would check the wireing
Posted on Oct 05, 2009
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Where is the waterpump on 2003kia sorento lx ?
Water pump is Timing belt driven. It is below the Camshaft sprocket, in the timing case. If you want to repair/replace it here are the instructions.
COMPONENTS
REMOVAL
  1. Using the drain plug, drain the coolant.
  2. Remove the drive belt and the engine coolant pump pulley.
  3. Remove the timing belt cover, the auto tensioner and idler pulley.
  4. Remove the water outlet fitting, the thermostat case and the water pump fitting.
  5. Remove the engine coolant pump mounting bolts.
  1. Remove the engine coolant pump assembly from the cylinder block.
INSPECTION
  1. Check the engine coolant Water pump for cracks, damage or wear, and replace the pump assembly if necessary.
  2. Check the bearing for damage, abnormal noise and sluggish rotation and replace the pump assembly if necessary.
  3. Check the seal it for leaks and replace the pump assembly if necessary.
INSTALLATION
  1. Clean the gasket surfaces of the engine coolant pump body and the cylinder block.
  1. Install the new engine coolant pump gasket and pump assembly. Tighten the bolts to the specified torque. Tightening torque
Engine coolant pump bolt:
Head mark "7": 17 - 22 Nm(170 - 220 kg.cm, 12 - 16 ft. lbs.)
  1. Install the water pump fitting, the thermostat case and the water outlet fitting.
  2. Install the auto tensioner and timing belt. Adjust the timing belt tension, then install the timing belt cover.
  3. Install the drive belt, coolant pump pulley and then adjust the auto tensioner.
  4. Refill the coolant.
  5. Run the engine and check for leaks.
Courtesy All Data LLC
© 2015 ALLDATA LLC. All rights reserved. Terms and Condit
Mar 15, 2015 | 2003 Kia Sorento
Kettler ergo racer squeaks and needs lube. How? Swc
Google for the manual online and you should be able to find it. Although they say they don't need lubrication.
Jun 01, 2014 | Cars & Trucks
Power Supply
Try emailing the parts department at Kettler USA: Kettler USA online shopping for tricycles pedal tractors ellipticals...
I used to have to contact them when I repaired Kettlers at the bike shop.
Feb 25, 2014 | Kettler Ergo Racer GT Indoor Cycling Bike
Kettler 67005127 belt
I just ordered a replacement belt (67005127) from Kettler USA parts.
Requests can be submitted by phone to 866.804.0440, fax to 757.563.9273 or e-mail to parts@kettlerusa.com. Model number of your product, your name, phone number or e-mail address
To ensure you have the correct part number, download the assembly & spare part manual from the corporate website in Germany.
1) To find the part number go to: Service-Center menu, select Assembly and Spare Parts
http://intl.sport.kettler.net/service-center/assembly-and-spare-parts.html
2) Select the category ("Crosstrainer" in my case) and enter the model number "XTR 1"
note: the space is important since it won't find "XTR1"
3) Select the appropriate document by selecting the language, and the download will commence.
4) These documents have an exploded assembly diagram and the list of all parts.
Nov 30, 2013 | Exercise & Fitness
I have a Kettler ergorace spinning bike which measures, amongst other things, recovery heart rate over a 1 minute period and then gives a 'Fitness Mark', but nowhere in the instructions does it say what...
from
http://access.kettlerusa.com/retail/manuals/fitness/crosstrainers/7653-309.A.pdf
you'll find that -------------- The computer calculates and assesses the difference between load pulse and recovery pulse and your resulting "fitness value" on the basis of the following formula:
Note ( F ) = 6 - (10 x ( P1 - P2 )/P1)^2
P1 = load pulse P2 = recovery pulse Value 1 = very good Value 6 = unsatisfactory The comparison of load and recovery pulse is a simple and fast method to control your physical fitness. The fitness value is a value of orientation with regard to your ability to recover after physical load. Before you press the recovery pulse button and have the computer calculate your fitness value you should train in your load range for a longer time, this means for at least 10 minutes. With regular cardiovascular training you will notice that your "fitness value" will improve --------------
Nov 23, 2010 | Kettler Ergo Racer GT Indoor Cycling Bike
Servicing
Locate where the noise is coming from, chances are the bearings have gone bad go to Kettler fitness.com they have contact info on their web site.
May 16, 2010 | Kettler Ergo Racer GT Indoor Cycling Bike
Kettler Ergo Racer GT Indoor Cycling Bike Logo
572 people viewed this question
Top Kettler Cycling Experts
dante
Donald Ayers-Marsh
Vern Reece
Vern Reece
Level 1 Expert
Are you a Kettler Cycling Expert? Answer questions, earn points and help others
