Question about Ionic Pro CA200 Air Purifier
Ionic pro red light won't go off,
Cleaned and cleaned it, still won't go off, cleaned the little wire cleaner too..driving me crazy...
SparkGap
  • 363 Answers
SOURCE: Can't clean Ionic Pro CA-500 inside?
Take it outside and blast it with compressed air.
Posted on Oct 19, 2007
SOURCE: ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
Posted on Sep 02, 2008
SOURCE: ionic pro won't turn on
The unit has an electronics malfunction. Return to the factory for repair. If you are a do it yourselfer then the problem should be obvious. it is NOT a fuse.
Posted on Nov 23, 2008
SOURCE: ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Posted on Apr 25, 2009
SOURCE: Repair an Ionic Pro
Here is the PDF manual. http://www.ionicpro.com/pics/ip_manual.pdf
Posted on May 24, 2009
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
My ionic pro air filters clean light will not go out. I have cleaned the blades but the clean light will not go out.
Hi Slipdope... make sure that you are also cleaning the ionizing wire. The wire cleaning mechanism is on top. Just pull up the tab and pull the cleaner up and down to clean the wire. If that doesn't work, call customer service at 800-875-8577 and they can do some trouble shooting with you and replace the unit for you if need be. Thank you.
Apr 23, 2010 | Ionic Pro TURBO Air Purifier
I placed the filters back in , but the clean red light is still on. this is an ionic pro compact cleaner
Try unplugging it, for a few minutes and wait then plug it in again and see if it resets.
Otherwise you need to reset it.
Most appliances that displays warnings have to be reset after it is corrected.
even your trusty automobile check engine light.
good luck.
Jan 30, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Repair an Ionic Pro
Oct 24, 2008 | Ionic Pro CA200 Air Purifier
Red...cleaninh light..
ame problem. I returned it to the store and they gave me a new one. So Far so good. My little ionic pro now keeps shutting off by itself. Have no idea why.
Jun 07, 2008 | Ionic Pro CA500 Air Purifier
Clean button
My ionic pro did the same, the red light just wouldnt go out, so I looked down the plate opening, (with unit unplugged), and could see one of the wires was broken. (these are the ones you clean by pulling up that plastic tab). I am currently looking for replacement wires, will post my progress. GregV
Oct 10, 2007 | Ionic Pro 901P2RIP04 Air Purifier
My.Ionic.Pro.doesn't.Blow!!
The red light means the unit needs to be cleaned. A blue light means the unit is working correctly
Sep 26, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic pro won't turn on
Solution, perhaps...
All electrical contacts can get a film on them. Try cleaning the contacts (at the bottom of the blade unit; you should see the three with the blades out) with an alcohol swab (make sure the contacts are dry before reassembly in this case) or a pencil eraser (vacuum the debris out before attempting to start it again).
If those contacts don't make up properly, the unit will think it needs cleaning, even though it doesn't.
Mar 27, 2007 | Ionic Pro 901P2RIP04 Air Purifier
Ionic Pro CA200 Air Purifier Logo
193 people viewed this question
Top Ionic Pro Air Purifiers Experts
David Gust
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
