Question about Frigidaire GLRS267ZA Side by Side Refrigerator
My Frigidaire, Model # GLRS267ZA is not cooling nor freezing. It began yesterday when I emtied the ice bucket into a cooler and then replaced the ice bucket into the freezer. Could that have damaged the compressor or caused it to stop cooling/freezing?
5 Suggested Answers
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
  • 358 Answers
SOURCE: freezer freezing and refrigerator not cooling
When it build up ice in the freezer the cold air can't go through to the fridge , this could be because : the fan doesn't work. the unit is low in refrigerant or the defrost timer or heater are bad , if the fan works take off the back pannel inside the freezer and if is only cover with ice part of it and the rest of the coil is clear of ice ,it means that is low on refrigerant (it is a seal system so there's a leak and has to be repair and recharged with freon), but if the coil is all cover with ice the problem is with the defrost system(timer or heaters) you can check the heaters for continuity if open replaced it if ok replace the timer.
Posted on Aug 08, 2009
  • 42 Answers
SOURCE: We emptied ice bucket to fill cooler. Now all we
There is a metal rod under the ice bucket. This rod sticks out from the back of the bucket. Where it inserts into the ice shelf, you will see a small square hole. This is what changes it from crushed to cubed. It is an actuator that moves the rod to allow cubes to come out. Stick a screwdriver into the square hole and move the actuator up and down. Then reinsert the ice-bucket and that should fix the problem. Hope this helps.
Posted on Mar 24, 2011
Whirlpool GD5RVAXVY05 dispensing problem
yep replace the motor and she is back to normal
Mar 22, 2014 | Whirlpool Refrigerators
The ice maker makes humming noise but is not making ice
Sounds to me like the water control solenoid has failed and is not opening to allow water to flow into the ice maker.
Jan 20, 2013 | Frigidaire GLRS267ZA Side by Side...
ED25RFXFW01 icemaker
Sounds like the=> W10408179 Dual Water Inlet Valve
has began to seep water at the valve and out through the ice maker fill tube and down into the ice bucket. About all you can do when this happens is replace the above W10408179 Dual Water Inlet Valve. I will be here should you have questions, Thanks Sea Breeze
How to test the valve can also be found HERE
Nov 08, 2012 | Whirlpool Refrigerators
We emptied ice bucket to fill cooler. Now all we get is crushed ice and not cubes. I can switch buttons from crushed to cubes but still get crushed. Did we do something wrong when I pulled out ice bucket...
Mar 24, 2011 | Frigidaire FRS23H5AS Side by Side...
FREEZER IS NOT FREEZING FOOD OR ICE IT IS RUNNING BUT THE ICE WILL MELT IN THE ICE BOX AND WATER WILL RUN DOWN THE FREEZER DOOR, NOTHING IS FREEZING. FRIDGE PART SEEMS TO BE WORKING OR KEEPING FOOD COLD....
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 08, 2010 | Frigidaire GLRS267ZA Side by Side...
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Food in fridge freezing solid
Sounds like you need to replace the THERMOSTAT , aj
May 05, 2009 | Frigidaire GLRS267ZA Side by Side...
Ice dispenser crushes ice when cube is pushed
the little gate/door, is a common issue, its a solenoid htat either burns out, or merelt freezes over. if you put your finger into where teh "shepard hook" supposed otgo, can you freely lift it ip and down???i would assum not, .the entire ***,bly lifts out of freezer( remove 2 1/4 inch scres under each corner and diconnect apower plug behind the ice maker. from ther you can try to defrost teh piston,if not rplace it.
Jan 02, 2009 | Frigidaire GLRS267ZA Side by Side...
Water leak
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
Apr 08, 2008 | Frigidaire GLRS267ZA Side by Side...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Frigidaire GLRS267ZA Side by Side Refrigerator Logo
102 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
