There is youtube video of plane front landing gear not coming down and a guy driving a Nissan truck drives out on the runway and the plane land front of plane in back of truck
SOURCE: A nurse at Sick Kids dropped my granddaughter's
Below is a link to the complete illustrated service and disassembly manual for your laptop. The laptop has to be torn down to the motherboard to effectively repair the cable where ir attaches to the frame. Usually these jacks slide into groves molded on the case, when they puched through, disassembly and repair or replacement is what is called for. Good luck with it.
http://tim.id.au/laptops/acer/travelmate%205720%205320%20extensa%205620%205220.pdf
Testimonial: "Looks like I am going to tackle this job myself. All the so called repair outlets only do the easy stuff and would send the unit to Acer ..cost $200. "
SOURCE: I lost my compaq presario V3000 laptop mother
Can you tell me exactly which series do you have?
Presario V3000 CTO Notebook
Presario V3000T CTO Notebook
Presario V3000Z CTO Notebook
I don't know which series do you have so i can give your the best answer.
Please go to: http://www.hp.com/#Support
choose "Download drivers and software (and firmware)"
and type "compaq presario V3000" and click "Go"
Have fun and good luck!
SOURCE: my hp pc laptop local
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Click on this link to download the drivers: -
www.hp.com/#Support
Hello
The engine and transmission in this cars
drive train is electronically controlled by a computer called
the PCM. Whenever a problem like this occurs the computer stores a
record of the problem in the form of a fault code in its memory, to
read these fault codes you must have the systems memory scanned with
a special tool. Once the fault code(s) are read you then must perform
the appropriate diagnostic testing to find and resolve the problem(s)
