Question about Epson STYLUS R230 InkJet Photo Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing I have tried the best how to set it but failed completely. If such is the case how can I get a help so that my printer should work?
  • 3 Answers
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Posted on Jul 15, 2012
Printer does print r230 red blink
Posted on Oct 06, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: when I try to print paper will come out without printing
In case anyone else runs across this, the problem is caused by a blown fuse on the main board. It is labeled F1 and it is near the 3 tall blue capacitors. If you have a meter you can check across it,if it reads anything more than a couple of ohms it is bad. This is a fast acting 2.5A fuse. You can get a fuse and fuse holder at on line or at your local Radio Shack or similar store. I know the 230 is the European/Asian version so I don't know if you have something like a Radio Shack. The R220 is the US version and it is identical.
You can jump it out but this is not recommended. If the fuse is not there, you could cause more expensive problems later.
Posted on Jan 21, 2014
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printing is really slow almost 10 mins to print i am using Vista and have had updated the driver for vista but still
Epson R230 print slow at PHOTO, very slow at BEST PHOTO, if you do not need photo quality prints try printng at TEXT AND IMAGE for faster printing and the quality is still good. Also try to lower the resolution of that you are about to print, high the resoluton images takes longer time to print. Hope this will help you, Good luck!
Oct 14, 2009 | Epson STYLUS R230 InkJet Photo Printer
When I try to print paper will come out without printing
1. Try to align printhead
2. Head cleaning with epson software
3. Reinstall driver and try to print
4. Check printer component, and ensure that's no broken part
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Blank paper print in R230
try checking the pump assembly of the unit. if it is clogged, the printhead wont clean and theres a possiblility that you will not get a printout. also check the head cable to see if there are no cut traces.
Feb 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
1,047 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
