Question about Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
It makes a clicking during the wash cycle but still completes the programme but I have water leaking from somewhere at the drawer and also the bottom I think.The wash is still spinning but clothes coming out wet.
  • Anonymous Mar 18, 2014
    and on the latest has started leaking a lot of water What should I do
Pump is working water is only a trickle coming out so wont final spin
Posted on Feb 27, 2008
  • 183 Answers
Check motor brushes, chech in pump for obstruction, if pump obstructed it would force water back up dispenser hose.
Posted on Dec 25, 2007
Hotpoint aquarius 1300 wma56 not draining. I've taken out the filter and cleaned. Put all back together, did spin cycle - all good. ran a full wash. Now stuck with water in not draining or spinning.
The motor is not reversing direction when it is supposed to pump out the water from the machine. The timer may be the problem or the motor itself.
Apr 26, 2016 | Hotpoint Washing Machines
Wont spin and the front indicator lights are going from pre wash to end in a night rider fashion
try checking ur door switch may also want to check the water pressure switch which signals the machine to go into wash after the fill cycle
Feb 11, 2015 | Hotpoint Aquarius WMA56 Front Load Washer
Our washing machine is leaking at the front. What are the most likely causes please, and how can I fix it. It is a Hotpoint Aquarius Extra WMA36 1300 spin. Thank you
It is so common that water leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked from the front then the door gasket can be fault and needs to be replaced
please check this link:
If there is leak at the bottom as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Sep 01, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Leaking water from door during spin
Most likely door seal, check all around the seal, as often very small holes are missed, then they open up during spin
Mar 09, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Machine takes in water then wont go any further
Main motor needed new brushes, all working well now.
Jan 16, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WMA56 Front Load Washer Logo
518 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
