Question about Electrical Supplies
200AMP Breaker trips same time every night
Hi.... For the last 9 nights, (but not every night) my main 200AMP Breaker keeps tripping, ironically, at roughly the same time every night, between 8:30 and 9:40PM. We are not running the AC. It happened Saturday Night 3x, and last night Sunday 2x.
We thought (I still think) it might be our brand new (2 weeks old) PV Solar Equipment, but yesterday AM the Solar Company, over the phone, had me power off everything related to the Solar system (turned off the DC breaker, flipped off the two inverters and turned off the 2 breakers relating to the PV equipment. Last night, it tripped at 9:20PM and again at 9:40PM. With the Solar equip powered down. I also have a USES system (shunt efficiency system), I turned those off the day before, and it still tripped with those in the ''off'' position. We have a 200AMP system in the basement which feeds the whole house, and an additional 200AM Square D outside (attached to the house) which we installed 3 years ago for the pool house, pool equipment, deck and outdoor kitchen.....that breaker is fine, only the basement one (the original) trips. The house was built in 2001.
I think it involved the Solar System (even though it's now ''off''), only because it seems too much of a coincidence that all of a sudden, we now have this problem, one week after the system was installed.....and what's up with it happening at the same time of day....any suggestions?
Jesse (jjb@jess.com)
  • 4,234 Answers
Something doesn't sound right here. You indicate 2 200Amp breakers. With a single service entering the house, this is not possible. The "sub-panel" to the pool house is more likely a 100Amp setup, yes? If not, you have a bad setup and it should be corrected. I would suspect that you are attempting to pull too much current to the pool and that is what is tripping the breaker. Also, these breakers should not be run over about 80% of their capacity for the long haul. If they are, they tend to age and get either real sensitive causing tripping when it shouldn't or you can run 500Amps through it and it won't trip.
My suggestion is to revisit the setup. If the pool house is fed from the main panel, make sure that the breaker for it is not 200Amp. Second, try disabling the pool house breaker to see if that is the source of the problem and look more closely there.
Keep us posted.
Dan
Posted on Jun 29, 2009
    New Friend:
  • 8 Answers
The breaker could also be on it's way out I've seen it before so don't rule it out
Posted on Mar 05, 2016
  • 575 Answers
I agree with Dan, Sub panels are feed from the main (200A) so the sub panel should be a lower Rating (100A). You should also have only one shutoff at the main for the sub panel.
Electric range breaker trips at night when all asleep, resets ok
Are you sure nothing else is using power? Sounds like a ground fault to me. Any devices which could cause harmonics which you can think of?
Feb 14, 2013 | Computers & Internet
Last night the frigidare AC with breaker in line
if the breaker reset and the display lights are lit its not the cord sorry to say could be compressor or fan motors.
May 06, 2010 | Maytag M7Y12F2A Air Conditioner
Eaton Arc Fault Breaker type BRAF tripped. I reset it but lights will not work. Ideas please?
My arc fault breaker trips in my bedroom when ever a load is put on line. The trunk line comes into a three gang switch box and feeds the entire room. At times I can turn my ceiling fan and light on for 10 to 20 minutes before the breaker trips. Other times the breaker will trip when either switch is first turned on. I plugged a 4 watt night light in a wall receptical, without the ceiling light or fan on, it also trips the breaker. I have had other plug in lamps, 60 watt, work in other recepticals for a while. The problem seems to appear in all recepticals and lighting in the room.
Feb 19, 2010 | Eaton ARC FAULT CIRC BREAKER
The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Feb 08, 2010 | Electrical Supplies
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
30 amp breaker trips intermittently
It sounds like this circuit breaker is worn out and needs to be replaced. good luck
Jan 19, 2009 | Siemens 2 pole 30 amp breaker
Electrical Supplies Logo
1,130 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
