Question about Car Audio & Video
Just bought a 2001 Lexus LS 430, the right side speakers come in and out with very scratchy sound and the AM reception is very bad, go about 15 miles out of Atlanta and can not receive a 100,000 watt AM station.
  • 93 Answers
When speakers get to this point there about to go out. You may want to replace it with another factory speaker, or just replace both with after market speakers. Not sure why your AM isnt picking up well, but you can buy a antena booster at your local radio shop or Walmart.
Posted on Jun 29, 2009
Is there a fuse I can pull to disable my passenger climate control on a 2001 LS 430?
No fuse that I know of.
The problem could be the zone control module, or the passenger side blend door actuator. All of the controls get power from one fuse.
May 14, 2013 | 2001 Lexus LS 430
I can't open my trunk or gas door on a 2001 lexus ls 430
At the driver side junction box (DSJB), check the 10A FUEL OPN fuse which is the source of power for the fuel door. The power is applied to the fuel lid opener switch that, when closed, activates the fuel lid opener motor and...POP!
Also at the DSJB, check the 15A ECU-IG fuse which supplies power to BODY ECU 1. At the passenger side junction block, check the 20A P FR DOOR fuse. Next, at engine room relay block 1, check the 10A MPX-B fuse. These three fuses apply to BODY ECU 1 which controls luggage compartment door operation. TSW output from the ECU is applied to the luggage compartment dooe opener switch which, when closed, activates the luggage compartment door opener motor and...POP!
Sep 28, 2012 | 2001 Lexus LS 430
Adjustable steering fault on ls 430
The steering column adjustment has stopped working on my Lexus LS 430 both manually and automatically.Any ideas?
Mar 05, 2012 | 2001 Lexus LS 430
When do I need to change transmission fluid on my Lexus LS 430 (2002)?
Under normal driving conditions, Lexus recommends not changing the fluid until 150,000 miles.
Feb 10, 2011 | 2002 Lexus LS 430
2001 Lexus LS 430- Driver side door will not open from the inside but it opens from the outside. Any suggestions on how to repair?
Yes, you have to open the door panel and inspect the linakage. Either something came loose and fell of, or something is broken..
Aug 22, 2010 | 2004 Lexus LS 430
How do i remove the driver side inner door panel on 01 ls 430
In the right side, work in the same procedure as in the left side.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect the negative battery cable.
  3. Remove the power window regulator switch assembly.
  4. Using a screwdriver, remove the front door lower frame bracket garnish. Tape the screwdriver tip before use.
  5. Using a screwdriver, remove the front door inside handle bezel plug.
  6. Remove the screws, then using a screwdriver, remove the front door trim board.
Fig. Exploded view of the front door components-LS 430 shown, other models similar
For other details, can visit autozone.com (free register).
Hope helps with this (remember rated) Good luck.
Jan 24, 2010 | 2001 Lexus LS 430
Ac filter replacement 2001 lexus ls 430
it is on the pass side of engine copartment . you have to remove a couple of covers. pretty easy.
Apr 20, 2009 | 2001 Lexus LS 430
2001 Lexus LS 430 subwoofer replacement
The outer cone is where the problem is, right where the fiber/foam of the cone material attaches to the outside metal frame. if you look closely, you will find the speaker is torn along this line, at least at some point(s). I used ge silicone 2 clear, make a bead all the way around, took about ten minutes, could not be better. Great fix. Also check lexus owners club for more detail.
Mar 05, 2009 | 2001 Lexus LS 430
Lexus ls 430 2001
are they not the same as the other cars where you will press a clip at the bottom of one of the post and you can slide out the headrest?
tnx 4 using fixya,
drcool
Oct 14, 2008 | 2001 Lexus LS 430
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
