Question about HP Compaq nx6310 Notebook
No audio device
There is no audio device showing when i go to
>settings > control panel > sound
i have windows xp professional
also NX6310 hp notebook
  • 70 Answers
If you are not finding the drivers for your notebook you can download it from the website www.driverpool.com here you to select your notebook model and choose the operating system that you have in your notebook and download the drivers( If you have a motherboard cd you can also install the sound driver from it)
Posted on Jun 29, 2009
My hp laptop nx6320 sound willnot play
Hello
1 Have you installed the correct and latest sound drivers for your laptop.
2 In control panel , sound options be sure your sound device is checked as default device and is on.Also verify volume is up.Use the qudrophonic or desktop sound option,
Sep 15, 2011 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Everything is ok but no audio output. Receiving audio through headphone jack only. What do I need to do?
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Sep 10, 2010 | HP Compaq nx6310 Notebook
I have HP laptop and i suddenly lost sound, i cant hear anything. i want the solution
Click start > Settings > Control Panel > Sounds and Audio Devices. Make sure it is not muted and volume is on high.
Click audio tab and under Default device is it set to SoundMAX HD Audio? if this device is not available try another device and click Apply and test. (you may need to close windows media player or whatever is playing the sound and reopen after changing default device)
Aug 23, 2010 | HP Pavilion DV6700T Notebook
Can not show volume icon on my pc
XP view
Control Panel
->sound,speech, and Audio Devices
->Sound and Audio Devices
->sound And Audio Properties
->check "Place volume icon in the taskbar" box
Classic View
Control Panel -> Sound and Audio Devices->sound And Audio Properties->check "Place volume icon in the taskbar" box
Hope it helps.
Aug 14, 2010 | Microsoft Windows XP Professional SP2
No sound card driver no sound audio
Try this:
Go to Start->Settings->Control Panel->Adminstrative Tools->Services
Then locate in the list of services "Windows Audio". Open this service
If this service is showing with a Startup type set to Disabled then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
If this service is showing with a Startup type set to Manual then Select "Automatic" from the drop down list then hit apply. Then click the "Start" button.
Next Go to Start->Settings->Control Panel->Sounds and Audio Devices then select the Volume Tab then put a tick in the box marked "Place Volume Icon in the Task Bar" then click apply.
With a bit of luck and following wind you should now have your sound restored.
Good luck
Apr 20, 2010 | HP (400745-001) Sound Card
Audio problem. computer speakers are working beeps etc, but radio and video no sound
In Windows XP, go to:
Start -> Control Panel -> Sounds & Audio Devices -> Audio
Ensure that your sound card, and not a USB device, is selected for audio output as the default device.
In Windows Vista/7:
Ensure that 'speakers' is selected as the default device.
Alternatively, if the beeps are coming from the computer case itself, please clarify as such with a follow up response.
Mar 19, 2010 | Lenovo 3000 N500 Notebook
Audio/volume problem
First, go to control panel - > Audio devices, then right-click any empty spot on the sound device, and show disabled or disconnected devices. If "Speakers" shows up, right-click and choose set as default (or something similiar). If this does not work, just reinstall your audio drivers. Right-click my computer -> Properties -> Hardware - > Device manager - > Sound, then find the sound cards manufacturer name, and right-click an press uninstall.
Jul 20, 2009 | Acer Aspire 4720 Notebook
Driver probem
the smbus controller holds the driver for ur audio device so first try to set the smbus controller driver
if it again shows a ? mark in device driver nothing happenns just make a forced installation of ur audio driver
Mar 18, 2009 | Compaq Presario 700 470024-192 Notebook
HP Compaq nx6310 Notebook Logo
150 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
