Question about Acer Extensa 5420-5687 Notebook
My acer Notebook Does not switch on
I have been working on my notebook with battery power. My notebook then switched of now after plugging it in it doe not want to switch on again. The power led is shining but when I press the power button it just flashes and nothing happens. If I press the power button five times on batter power the power led flashes orange 5 times and then nothing... After connecting to the power source the led turns green as if charging but I can't switch the notebook on.Help I'm getting desperate now.
  • bmeher2 May 11, 2010
    Acer notebook has soft and small switch some time switch cann't receive power press longely
    or please serviceving the notebook or change the switch or change the CPU Battery .
  • 71 Answers
Well you can reseat the RAM and check if that does not fixes the issue, it could be an issue with the system board . You can contact Acer support line, if the unit is under warranty you can have system board replaced.
Posted on Jun 29, 2009
Bios cmos password reset
Remove the laptop battery, locate the cmos battery inside the laptop, remove it then wait 5min, plug in the power, switch on the laptop and then the moment it switches on remove the power plug. Then put the cmos battery back, then the laptop battery and turn it on. All should be right. Referring
Oct 31, 2013 | Acer TravelMate 233X PC Notebook
What stops computer from starting up
hi
turn off the notebook. take a regualr desktop monitor VGA or LCD monitor and plug into the notebook (make sure to power up both the notebook with AC adapter and power cord for monitor). Turn both on and you should see video on the desktop monitor . if you do not see anything, i would hint at the fact that the notebook screen may be bad. Do you hear the hard disk drive spinning when you turn on the notebook ? if so, thats a good indication that the mainboard is still working and that the LCD screen on the notebook is not functioing . You will have to replace the LCD (notebook) screen
Jan 04, 2012 | Acer Aspire 5630 Notebook
I have a Acer Aspire 5253 notebook that just switched off and when booting up only the ON button comes on but the pc does not switch on. Please advise on how to fix this.
Try this
  • Unplug the power cable
  • remove the battery
  • press the Power On Button (on your notebook) for 30-60 seconds
  • Plug-in the Power cable
  • Press the start Button
Hope this help
Dec 24, 2011 | Acer Computers & Internet
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
My notebook wont turn on and it there is no power
remove battery and plug in power adapter try to switch on, if working power off again and insert battery and switch on again if not working maybe your battery is dead. try to replace new one.
Apr 19, 2010 | Acer Aspire One PC Notebook
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
Acer 290 bios password reset
Hi, Keith.
Remove the bottom of the notebook.
See if you can remove the CMOS (round, silver) battery for 30 minutes.
If not, on the motherboard, note the bank of four switches. Normally, they would be off. I believe that if you turn on switch 3, the BIOS and boot password would go away.
Hope this helps.
Sep 28, 2009 | Acer TravelMate 290 Notebook
Acer 5570 - Power switch is not working
Try removing the power supply (from the wall) and the battery pack. Hold down the power button for 30 seconds. Plug the mains power (from the wall) back in and then press the power button. It should work. Then you can replace your battery pack. Don't know why it works but it has worked for me in the past. Good luck!
Aug 01, 2009 | Acer Aspire 5520-5908 Notebook
Acer aspire 5100 notebook kb and mouse doen't work on boot up
Try to remove ram memory and put it back after a while. Do it on removed battery.
Mar 22, 2009 | Acer Aspire 5100 Notebook
Acer notebook screen will not energize?
Hi, If you keep you battery for a long periode of time without using it it may damage and damage you system too. Remove the battery and check weather any junks are there on battery connector. if it is there clean it and try to boot without battery and check. thanks arun
Aug 12, 2007 | Acer (91.AD303.001)
Acer Extensa 5420-5687 Notebook Logo
364 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
