Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
CAMERA HAS NO POWER WAS WORKING PERFECT TILL BATTERIES WERE REPLACED HAVE TRIED OTHER BATTERIES BUT STILL NO POWER DID NOT DROP OR DAMAGE CAMERA IN ANY WAY
  • 73 Answers
There is a fuse on power section u can c on that written f01 .then join that fuse or replace
Posted on Jun 29, 2009
I dropped my Nikon D60 and now it does not power on I would like to know why???
There are several possible reasons. One is indeed the battery. If the camera powers on with a different battery pack then that would point rather conclusively at the battery.
Another possibility is that the drop damaged or broke the battery contacts inside the camera. Another is that the drop damaged or broke something else inside the camera.
First, try another battery pack. If you don't have one, go to a Nikon dealer and ask to try one. If the camera powers on with that, then buy a new battery and dispose of the old one. If the camera doesn't power on, then you'll have to have the camera serviced.
Dec 16, 2011 | Nikon D60 Digital Camera
I have a samsung ES55 camera when i try to turn it on the lense pops out then straight back in and the camera turns off it will not turn on please can you help thank you
If you've recently dropped the camera this problem may be due to lens damage, with the camera shutting down to prevent further damage. If this is the case the camera will need professional repair.
If it hasn't been dropped this problem can usually be attributed to the camera's power supply. Make certain that your batteries are serviceable and fully charged - batteries more than one year old are candidates for replacement, especially if the camera sits idle for weeks at a time. Also check the battery and camera contacts for corrosion that can build up and prevent the required power flow between the batteries and camera. Even if you don't see any buildup, wipe the battery contacts and camera contacts firmly with a clean dry cloth. Heavy buildups may require cleaning with a fine wire brush, steel wool, or even sandpaper. After cleaning, be sure to remove any residue from the battery compartment before installing the batteries.
While the above steps will not cure ALL power problems, they are effective in a large percentage of cameras. I hope they work for you.
Nov 23, 2010 | Samsung Cameras
Battery is fully charged but camera does not work, lens stays inside the camera, nothing works
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 09, 2009 | Samsung Digimax L830 Digital Camera
Lens does not extend out after power-up.
If you've recently dropped the camera you may have lens damage that is preventing the camera from powering up. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 30, 2009 | Kodak EasyShare CX7530 Digital Camera
Digital camera Samsung Digimax 360 repair
If you've recently dropped the camera you may have lens damage that is preventing the camera from powering up properly. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please post a rating for me. A rating of "Very Helpful" would be appreciated . . .
Nov 25, 2009 | Samsung Digimax 360 Digital Camera
I have a Canon Powershot A550 and I recently dropped it on a night out. Since then, now matter how many times I have changed the batteries to fresh Alkaline batteries, the camera tells me to "change...
The internal connection is damaged or circuit board is damaged . You try to tap on the sides of camera and check whether the message is disappeared .
Also possibility that battery contact is damaged so try giving power to camera through power adapter . If this works then you need to replace the battery holder .
If your problem still continues then you need to take to service center to get it repaired .
Thanks for using Fixya
SAM ANDERSON
Dec 11, 2008 | Canon Cameras
Troubelshooting
when digicams are dropped most problems occur because some cables or wiring connections got loose. try taking it to a camera specialist to have it checked because if you open it yourself it might cause more damage.
Jun 19, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Camera wont turn on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 27, 2008 | Canon PowerShot S45 Digital Camera
No power
Directly from Kodak's website:
IMPORTANT
We recommend that you do not use alkaline batteries in EasyShare cameras because they may cause unexpected shutdowns and loss of pictures.
Jan 19, 2008 | Kodak EasyShare CX7300 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
170 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
