Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
I have a Brother C2890A fax machine and want to know how to set the machine to not pick up on the first ring for fax so I can answer the phone with incoming calls. I am set up on an incoming phone line through cable
  • 294 Answers
Brother let me tell u its not a big deal.. and really a genuene question dat i get from my clients.nw let me help u step by step here.. A receiving mode is a setting that changes the way your machine responds to incoming phone calls and faxes. In the units that have a Jog Dial and no built-in answering machine, you can use an external answering machine in any receive mode(wiz u hv done) Plug the answering machine into the Ext.Tel port in the back of the fax machine, and make sure the ring count of the answering machine is lower than the ring count of the fax machine (press Menu, then turn the jog dial until you see ring count, and press Start — you can then change the ring count of the fax machine).Tel receiving mode:In this mode, any extension in your home can be used to answer a call. If the incoming call is a fax, dial the fax activation code (usually *9, or see user's manual), hang up and your fax machine does the rest.
Tel/fax receiving mode:Your fax machine will automatically receive incoming faxes when set in this mode.
ANS/FAX:In this mode, incoming calls can be set to ring up to 4 times before your fax machine answers the call, to give you a chance to answer the phone. After 4 rings, the answering machine will pick up a regular (voice) call and the fax machine will initiate a fax call.
EXT.TAM:This receiving mode allows you to use an External Telephone Answering Machine. You can connect a separate answering machine to your fax machine and set it to receive voice messages and faxes while you're away from home.i could be hurt if m not answering ur question cz i hv 11 years experiance.. this old man deserve a drink.. wat u say?? take care!!
Posted on Jun 29, 2009
HOW TO RECEIVE A FAX
make sure the phone cord is in the right slot and make sure u are getting a dial tone if not could be phone line issues call the number yourself and make sure your getting a clear ring
Aug 28, 2009 | Brother IntelliFAX 1840C Plain Paper...
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
BROTHER FAX 1840-C.
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
Trouble
Set the reception mode to fax tad. (Telephone answering device). Lawrence
May 24, 2008 | Brother IntelliFAX 2800 Laser Fax
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
