Question about Linksys PAP2T
The Line LED does not light and there is no dial tone
On phone press asterisk 4 times and at the prompt select option 110 followed by #, jut set nine up , I had the same problem
Posted on Sep 10, 2009
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
Inoperative fax and telephone line
try connecting line 2 to a simple phone and chk for dial tone.
Sep 22, 2008 | Canon FAXPHONE L80 Laser
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
Line lights 1 & 2 on. No dial tone
The lights are controlled by 2-AA batteries per line (they are not necessary to just make calls) - The dial tone, I don't know, but you have Line 1 & 2 as one Plug, plus Line 2 and there are 2 Data plugs all in the back.. so...you know
Mar 09, 2011 | AT&T 982 Corded Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Won't dial out
might you have your phone set for tone on a pulse line???
Do you know what kind of line you have?
You can use pulse and/or tone on a tone line. But you cannot use tone on a pulse line.
A pulse line is cheaper ... I have a pulse line from the mid 70's and I refuse to upgrade it (costs more) to tone - whats the point - I never get any calls and im not in that big a hurry to dial for the extra couple bucks they want.
Oct 13, 2009 | Lands Phones
Bought phone EX18560 Series yesterday. floolowed instructions to charge. Today I came home from work, plugged in telephone jack. phone will not turn on. Attempted to re-register (4X's). Led flashes....
I have two older (2002) model cordless Uniden phones that require the handsets to return to their original factory bases. If they have rested on another Uniden base, even of the same model, there is no dialup tone. Replace to the original base and you should be back in service.
Aug 11, 2008 | Uniden Lands Phones
AT&T Spirit Phone
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom, Press speaker, Dial *0, Dial 1, Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Aug 05, 2008 | AT&T Spirit 6-Button Stard Misty Phone
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
dialing.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
Linksys PAP2T Logo
349 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
