Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
Directory corrupted - unreadable.
WD 160GB HDD subfolder corrupted while copying photos from Compact Flash card. Also several JPEGs have incorrect marker in a nearby folder. Original files were located in now corrupt directory so cannot re-save them from original raw files.
    President:
  • 627 Answers
Try to run chkdsk (checkdisk) ---- chkdsk c: /f /r
also probably you need recovery software (easy recovery professional)
Posted on Jun 29, 2009
Shot with Lexar Professional 233x 16 GB compact flash but can't retrieve images.
Connect compact flash to a Windows box. Check Disk with Repair and Fix.
Go to Start > Run (Search). Type cmd ENTER. From the Command Prompt type chkdsk x: /r/f ENTER. X being the drive letter.
Oct 24, 2012 | Lexar Electronics - Others
I have a 1 tb WD drive and it is saying my directory is corrupted and unreadable. I haven't dropped it or done any changes to it and I do not want to loose my files on it. What should I do to repair it?
Hi
1. To copy your files before you start the fixing part you can try this FREE download:
http://roadkil.net/unstopcp.html (Unastoppable Compier that I use in my business and saved many of files for me)
or
http://www.pcinspector.de/default.htm
Then after you have copied all your files you can format the drive without any problems. If you still get issues reading or writing to the drive after format, go t ocommand prompt under accesories and then run as administrator.
In command prompt you can do type the following and press enter: "chkdsk f: /r ("f:" being the hdd drive letter)
This will chack and repair sectors on the disk
Hope this helps
Feb 03, 2011 | Western Digital Passport 160GB External...
I have a 16GB sandisk compact flash card that will not let me delete the files. I keep getting a "directory corrupted or unreadable" error. Help!
Seems to me the devide is damaged. You will have to format it.
To do this :
Open My Computer
Right Click the device name
Click format
May 19, 2010 | Computers & Internet
Cruzer micro 2GB - "Directory or file cannot be created"
In all likelihood, your SD card is formatted FAT and you are hitting the limit on number of objects in the root directory. Check the format type and if it is FAT, I would recommend reformatting as FAT 32 which has more lenient restrictions.
ALTERNATIVE: If you really do not want to reformat the card, you might try to remove a few pics to free up space in teh directory and then create a subfolder to store picture in. Object in this subfolder should not be counted at the root.
Aug 12, 2009 | SanDisk 2GB microSD Memory Card
Memory card will not show up on my computer.
Verbatim compact flash card has over 200 photos corrupted files. I volunteered to take photos for local senior anniversary I was the main camera now, I have lost the content. Files are Dcim--JPO, POG and worse coded files not JPEGs and I even with trial acdsee repair I am unable to rename and restore these photo files. CVS photo was able to open some of the files with their program but advised we would need to find the proper recovery program to restore some of the files.HELP
Jul 20, 2009 | PNY 4GB Secure Digital High Capacity...
My card won't work on my computer, what is wrong?
When you format the card, be sure to do it in the camera, as the camera firmware writes hidden files to the card.
When you insert the card into the card reader, be sure to set write-protect, so the contents cannot be corrupted.
I suspect what may have happened is that at some point there has been a conflict between files written to the card by the camera and the computer.
May 13, 2017 | SanDisk ULTRA II 4GB Compact Flash Card...
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Problem downloading pictures from memory card
Hi flashlal - I have a Cannon PowerShot S400 and I had a similar problem which uses a compact flash card. I could only view a few photos and it seemed like the rest were gone. I verified that my photos were on the compact flash card when I installed it in my pc and navigated to the compact flash card (You can do that by double clicking on the "My compute" icon). Then double click to the directory to where your memory card is located and navigate through the files. I noticed that my photos were there because the file size was in the hundreds of kilobytes (700KB and up), but the names of all the files were corrupt - they had symbols in the name. I figured at this point I had nothing to lose so I did a "check and repair disk" on the compact flash. To do this: take note of the directory that your memory card is located in (it should be something other than C:). Once you know where your memory card is located, you go to your start button on the PC, then to run. A pop-up window appears.The command to repair your disk is "chkdsk /f", however you have to tell it the directory of where your memory card is located. For me my memory card was in the E: drive so I had to type:
chkdsk e: /f
Once it finished running I went back to the my computer window and navigated to my compact flash folders. I looked at my photo names. I had to rename all my photos by putting the extenstion of "JPG" back as the file type. Once I did this, I could then view my pictures. The only thing I lost was the added information that my camera puts on it like the date, time, and camera setting used to take the picture. I was fine with not having that because it was more important for me to retrieve my pictures.
Good luck.
Sep 26, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
1,160 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
