Question about Nokia N70 Cellular Phone
Audio problem. my phone rings when i receive calls but can't hear the voice of the caller.
  • teenax_roper Jun 29, 2009
    i actually lost my headset and not using one for over a year. any alternative solution please?
  • 390 Answers
Check if the volume has been set to low if not then add a head set to check if you can the hear the other party's voice
if yes then you may have to replace your ear piece in the phone
cheers
pls rate the solution
Posted on Jun 29, 2009
  • Pavan Ponangi
    Pavan Ponangi Jun 29, 2009
    what i mentioned earlier is an alternative solution
5 Suggested Answers
SOURCE: Cannot hear other callers voice nor I could hear their phone ringing !!Pl. help
I had the same problem a while back. What I did was test the speakers using the phone's own system check menu. You can access this menu by doing the following:
Wheel up, *, Wheel down, Wheel down, * Wheel down
If you have successfully done this, the service menu will appear. But be careful not to change anything on the setting that you do not understand. Just try the system check/test. If the speaker test proved the the speakers are working, then, instantly, your phone's speakers will work on your next call.
Posted on Feb 12, 2008
chaistars
  • 172 Answers
SOURCE: When the phone rings and
you can try to use a headset and see if it will work
normally if the caller cannot hear the receiver theres some problem with the mouthpiece. if the headset and loudspeaker works then you have to go to the store and have it fixed.
hope this help
Posted on Sep 08, 2010
CHAUDRYATIF1
  • 140 Answers
SOURCE: Can hear phone ring, but cannot Hear Callers, and
DEAR YOUR MOBILE'S EAR PIECE HAS BEEN DAMAGED JUST GET IT REPAIRED BY A PROFESSIONAL REPAIRER. IT IS NOT A BIG DEAL JUST A MATTER CENTS I THINK . CAUSE I DONOT KNOW FROM WHERE U ARE. HERE IN PAKISTAN IT IS ONLY A MATTER OF 0.90$ WORK.
Posted on Jan 23, 2011
Ezrahite
  • 2632 Answers
SOURCE: phone rings,no voice to be
Welcome to Fixya. It seems to be the the problem of your phone is the ear piece. The ear piece is different from the speaker of your phone and that's the reason why you can hear the caller on loud speaker. If sometimes you can still hear the caller then the earpiece is still working but need to be replaced. You can check the warranty of your phone and have the earpiece replaced.
Thanks
Posted on Jul 31, 2011
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
Why are calls not coming into my lg g3?
www.lg.com/us/support/mobile-support
1 (800) 243-0000
Sep 08, 2014 | Cell Phones
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
When the phone rings and the person answering the call can hear the caller the problem is: the caller cannot hear the voice of the person that answered the phone.
hope this help
Sep 08, 2010 | Cell Phones
Caller can not hear me on receive call,
Sounds like 1 of 2 things
1. You have your phone muted :)
2. Your microphone does not work
A simple way to test your mircophone part would be to, if it has one, if your phone has a voice memo or voice recording feature use that and try and record your voice if it doesnt work, replace the phone if it does we're one step closer to figuring it out.
I'd start with that
Also check your manual for a phone reset feature and try that as well
Nov 01, 2009 | Panasonic Lands Phones
Can't hear the Ring
Hello, Push the center button(in the middle of the four directional arrows). Scroll over to the screwdriver/wrench icon and select it. Scroll down to the "Audio" line and select it. Scroll down to "Loud Detail" and select it. Set "Ring Volume" to a higher number(I use 7). Have someone call you and you should be set. If this doesn't work, with the phone open, look at the two buttons on the left side of the phone, push the top button until you have your desired ring volume. Good luck!
Jul 26, 2007 | Motorola Mobility V710
Voice sound has gone on phone (but ringtones and all other sound working).
there is problem inside ur phone. the speaker which gives sound to listen in caller's voice that has spoiled. take it to technician it need to be replaced
Jul 02, 2007 | Panasonic G50 Cellular Phone
Nokia N70 Cellular Phone Logo
248 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
