Question about InFocus ScreenPlay 4805 Multimedia Projector
Color wheel for a 4805
I need to either repair or replace the color wheel in my projector. Can somebody please tell me how to do so and where I can find the parts? Thank you
  • 26 Answers
Re: Color wheel for a 4805
You are describing two separate problems. The line (or shadowing) on one side is a light tunnel failure. The whining noise is a color wheel problem. It wil either freeze up eventually and the projector will shut down or the glass will shatter and you have a black & white image.
Posted on Feb 28, 2008
I've encountered this same issue. I had a large Yellow Line down the left side of the screen for a few months. It got bigger and bigger, then one day I was using it and Bam! What sounded like a fire cracker was my color wheel exploding. I also had the rubbing sound, or at least something similar to that sound prior to the explosion. InFocus quoted me about $300 to fix..
Posted on Jan 26, 2008
0 characters
3 Points
Just replaced burnt out bulb in Infocus 4805 projector. Great picture with new bulb but only black and white. Is this a bulb issue or something else in the projector?
This is most likely the color wheel. When the bulb blows, it can damage the color wheel. The color wheel is a wheel composed of thin layers of colored glass that spins in front of the projected image. It is possible to repair it with super glue, but the best way is to try to find a new one to buy.
Dec 29, 2010 | InFocus ScreenPlay 4805 Multimedia...
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Lost color on infocus 4805 what needs to be done to repair this I just bought a new lamp then the color went
    your color wheel needs to be replaced. i have the procedure listed in another of my solutions. this is a major repair for the inexperienced
    Jul 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Color wheel in my InFocus ScreenPlay 4805 projector
    The 4805 Color wheel part number is 525-0146-00
    You can buy it from AV SOLUTIONS in NY
    As far as if it's worth it... That's up to you.
    Nov 07, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Color wheel
    Bid on a used Infocus 4805 on Ebay...So far thet is the cheapest and best fix for a color wheel
    Jul 22, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Glass prism
    Thanks for contacting us regarding your product questions or concerns. It appears you are wanting to know how to reach the glass prism from your 4805?
    My initial question would be, why are you looking to access the glass prism in your 4805? This is a very dilicate process internally of your projector which helps it opperate. Are you trying to self-repair your projector?
    Let me know. I'll be waiting for your reply.
    Dec 28, 2007 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    302 people viewed this question
    Top InFocus Multimedia Projectors Experts
    Juan Carlos Pacheco
    Level 1 Expert
    Are you an InFocus Multimedia Projector Expert? Answer questions, earn points and help others
