My Whirlpool AC Model acm184xa1 stopped working yesterday. The compressor appears to still work since the evaporator gets cold but no fan. Can anyone help me trouble shoot this unit? Thank you
  • 396 Answers
REmove the fan and check it separately, if it runs out of the unit you have a relay switch gone bad.
Posted on Jun 29, 2009
AC works for about 300 miles then stops and blows hot air. New AC compressor and freon charge. After sitting for a while it will again blow cold.
I think you have a similar problem to mine. At highway speeds is when it happens. And it is not blazing hot? Right?
Your evaporator is freezing up - as this happens the ice surrounding it prevents the flow of air over the evaporator coils and the result is warm air coming out of the registers. If I turn off the AC for about ten minutes and let unit melt the cold air comes back. This does not occur in stop and go driving.
I combat it by either running the fan at a higher than normal setting to increase air flow over the evaporator and then turning off when it gets too cold, OR using the air control to allow warmer outside air to enter into unit at highway speeds to prevent freezing up.
Newer cars have more sophisticated sensors and controls to prevent this but some older vehicles are subject to this anomaly.
Since it works fine under normal conditions I have not messed around with the freon level in system. If you release a tad of refrigerant the low pressure switch will shut off the compressor sooner and help minimize ice buildup. Good luck.
Aug 19, 2016 | 2000 Ford Taurus
Why has my freezer stopped cooling ?
The freezer does not get cold the evaporator fan motor might have stopped working.
http://thesisreviewadvisor.com
Jan 08, 2015 | Refrigerators
Exterior CKL49-1A AC Unit not blowing cold air
Why you need to change evaporator coil when condenser fan not working ,also why would you even charge unit with looking for leak.
Maybe the evaporator coil is leaking and when you recharge it it work for couple of days now unit is empty again .
If unit have low pressure switch then outside unit would shut off.
Jan 05, 2018 | Coleman Heating & Cooling
I have a 97 Toyota Camry. The AC has been working great and gets really cold. Yesterday as I am driving the light on the ac power button starts to blink, after about 45 seconds the ac turns off and stops...
CHECK THE AC AND HEATER CONTROL FUSE.MORE LIKELY FUSE BLOWED BECAUSE AC COMPRESSOR COULD HAVE FAILED IF LOW SIDE IS OVER 100 PSI. THE REED VALVE PLATE IN COMPRESSOR PROBABLY DAMAGED CAUSED COMPRESSOR FAILURE BLOWED THE HVAC CONTROLS FUSE. HAVE AC SHOP CHECK IT OUT.
Aug 29, 2011 | Toyota Camry Cars & Trucks
My refrigerator stops working yesterday. Compressor and compressor fan seems to be working....inside fans are working but its not cooling, freezing or making ice.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 28, 2011 | Samsung RFG299AARS Stainless Steel (285 cu...
Hi, I turned the refrigerator off to clean it out, turned it back on but not getting cold the freezer is working fine. Its a whirlpool about 3-5 years old. model # er2chmxpoo4.thanks hope you can help....
Do you hear a fan running in the freezer? If not, then you'll need to replace the evaporator fan motor, located in the freezer compartment behind the evaporator cover. Part # W10189703 . Now the fan would only run if the compressor was running, so turn the dials all the way to the coldest setting and check again to see if the fan is running. Hope this helps.
Mar 23, 2011 | Whirlpool Refrigerators
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Frig section not cooling and at time appears to stop but freezer is ok
There is one compressor, condenser and evaporator in all refrigerators. The part that makes the cold inside the unit is the evaporator. It's in the freezer, behind a barrier on the back wall. It's a "coil" with many small fins. There is a fan that blows air over the evaporator which makes the air cold. This air comes from the freezer and stays in the freezer. The cold food section (the refrigerator) has a control that opens a hole for air to pass from the freezer to the fridge. This being said...you can rule out the "temperature control" for the fridge.
The sound you hear could be the compressor relay, the evaporator fan or maybe something else. It could be bad, it could be not too bad. (Like a fan blade a bit unbalanced with dust)
OK,,, back to the evaporator. There is a little heater next to the coil that turns on every 8 hours or so to defrost the coil. That's called the "defrost cycle". Makes sense, no? If the defrost timer (common problem) or defrost control board (common problem) go bad, your evaporator coil freezes up, and that's not good for anything in your refrigerator. But it can often keep the freezer section cold. You can easily disassemble the evaporator cover in the back of the freezer and take a look. If it looks like a block of ice, you probably have a defrost issue. An even, thin coat of frost is OK, but lots of ice is a no no.
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
