Question about Motorola Mobility ROKR E6 Smartphone
Side key lock is not responding when i try to slide it open
It means it has lost the grip with the internal button. remove the side key lock with the help of smthing. n push the internal button with the stylus,n go for a new side key lock.
Posted on Jul 02, 2009
Passenger side door on 1998 olds 88 locked and cant get it open even with key
Doubtful. I'd recommend a good locksmith to come pop the lock for you fron the window channel. If you know what to look for, just roll down the window, find the lock linkage, and pop the lock yourself.
Mar 13, 2014 | Oldsmobile Cars & Trucks
Can not put key into ignition
There will be a white plastic barrier preventing key entry. Slide a slotted screwdriver along the side of the barrier and slide it to the left exposing your key opening.
Sep 18, 2012 | 2007 Volkswagen Jetta 2.5 Sedan
Remove lock cylinder from trunk
Depending on the vehicle, there is probably a U shaped slide clip that holds the lock cylinder to the body of the vehicle. It simply slides onto the cylinder against the deck lid. It should have a lip on the opposite side of the U opening to grip in order to slide it off.
Dec 15, 2017 | 1992 Chevrolet Lumina
Need to open the electrolux vacum
The locking key on the side of the vac has a tightening wedge on it so it doesn't slide easily. Spray the entire key top and bottom with WD40 or similar. Grasp at the bag door area with vise grips and pull the key straight forward.
If the key will not slide, you will need to take a large flat bladed screwdriver and lay the blade flat at 90 degrees against the back end of the key. then strike the side driving the key forward toward the bag chamber door. Do not twist.
Aug 22, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Trunk qill not open
Your trunk lock actuator is probably in valet mode. Take the mechanical key out of your smart key(should have a release button on the bottom of the key which will allow you to slide the hidden mechanical key out of the plastic housing) insert it into your trunk lock actuator and turn to change your function of trunk actuator. In the valet mode the trunk does not respond to your central locking or release button commands. Your owner's manual will tell you about these features. I hope I have been helpful
Jun 28, 2009 | 2002 Mercedes-Benz S-Class
2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
Jun 16, 2009 | 2003 Honda Pilot
The Door Handle Will Not Unlock!
Remove both sides of the handle and you should be able to slide the lock mechanism so the door opens.
Oct 08, 2008 | Locks & Locksmithing
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Battery died now power sliding doors and rear hatch not operating
1) Unlock all doors from driver's door while it is open. The driver's door is the only door to remain open during this process! 2) Turn the key from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. All the doors will lock and unlock if program is successful. 3) Turn key OFF and remove key from ignition. Within 20 seconds, press any button on the remote. (Press sliding door or rear hatch and it will open!) 4) If door locks do not respond, wait several seconds and press button again. If doors still fail to respond, try repeating steps (1-3).
Jun 16, 2008 | 2005 Ford Freestar
Motorola Mobility ROKR E6 Smartphone Logo
172 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Unlockingcom
AJMAL KHAN
Tom Chichester
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
