Question about Belling DB90 Electric Kitchen Range
Replacing the oven bulb
Anyone please help me, all I want to do is replace the oven bulb and is says in the manual all you do is unscrew the glass bulb cover and then replace the bulb unfortunately they don't mention that the glass cover doesn't unscrew. Any ideas would be greatly apprecaiated.
Re: replacing the oven bulb
Try taking the cover for the fan and element off -- I found this is the only way of getting a decent grip on the glass. It's four Philips screws. Obviously make very sure the oven's properly cold and isolate the electricity supply before you do it!
Posted on Aug 26, 2009
Smear rear fitting with cooking oil .Wrap lens with gaffer tape for better grip and to save breakage.With pliers or wrench unscrew anticlockwise.
Dave from Devon
Posted on Feb 19, 2008
  • 473 Answers
It does unscrew put they are usually on there very tight. You could try using a strap wrench to take it off. It turns counterclockwise to loosen.
Posted on Nov 07, 2007
0 characters
3 Points
How do i change the oven bulb in jer8885qas
I hope this may help you if it doesnt have visible screwss etc.
Sometimes the glass lenses are held in place by clips behind them which are not visible.
I am not familiar with your machine but I suspect the lens in thick glass and is slightly 'proud' of the oven side.
You have to have faith that it wont break it, but you have to CAREFULLY lever the lens out of its fitting using something like a blunt screwdriver. Once you get one side started, you will get the idea. The bulb is right behind it.
Sep 15, 2014 | Jenn-Air JER8885QA Electric Kitchen Range
How to change out the light bulb
Please check this video for bulb replacement, it's an example though:
Hope this helps...please post back with manufacturers name and model no. for further assistance.
Mar 20, 2011 | Kitchen Ranges
I cannot turn the glass to replace the bulb as per the manual. Manufacturer recommends a suction cup if necessary, which I do not have. Any other recommendation?
Sorry to read about your problem, I hope this helps you out.
turn off power to oven,
put small hand towel around bulb, try to remove. if still frozen break bulb, have vacuum ready to collect glass. get heavy long nose pliers and grab inside glass and wire and turn.
if you dont feel like doing, contact a service company..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kitchen Ranges
I have a kenmore glass top stove model # 66595781000 and need to change oven light how do i get the dome off to do this???
Recommended - unplug the oven before starting. The cover on the light should unscrew (turn counter-clockwise). The bulb also comes out by turning it counter-clockwise. Replace with a 40 W appliance bulb and turn clockwise to replace. Then replace the dome by turning it clockwise.
If you are having a problem, check if there is any surface dirt or a cross-threaded piece. If overtightened at some point, it could be hard to remove. Try using a plastic gripper (for opening jars) if you have one. Alternatively, you might try a soft rubber strap wrench - use very carefully. When replacing, make sure to only get the dome hand tight. Overtightening will damage the dome.
I hope this helps.
(for additional information: the manual is available here:
Nov 27, 2010 | Kenmore Kitchen Ranges
How do you change the oven bulb in a GE Profile Convection oven?
Unplug or flip breaker to the range. Remove wire around glass bulb protector by sliding one side out of clip while holding onto glass protector so it doesn't fall into the oven and break. Unscrew old bulb, replace with new one. Hold glass bulb protector over the bulb and hook wire back into its clip. Voila! Back in business. (I didn't unplug it, but discovered that you can't turn off the bulb, so it shines in your eyes while the oven door is open. Also, very stupid thing to do, since the bulb could very easily have broken in my very clumsy hand and given me a bad shock. So do it right, and unplug!)
Jun 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Could you please advised me how to take a bulb out of my Hoover oven and how to replace? Many thanks Jeanette
Before doing any work on an electric range or oven, make sure it's unplugged, or turn off the power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
you'll want to replace it using these simple instructions.
Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  1. Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  2. 3Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.4
  3. Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  4. Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back. 6
  5. Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb. In most microwaves you simply have to take the cover off by unscrewing holding screws. Replacing bulb is pretty straightforward, simply take out holding screws, disconnect leads, and remove bulb from place.
    To install new one,reverse steps.
    Usually it is really hard to find replacement parts. It is usually better if you take microwave name, model and serial number, and take info to a place that specializes in appliances
Tips & Warnings
  • Consider replacing the switch on the oven door if you replace the bulb and the light still does not work. Shut the door and open a few times or press the button manually to see if the light works randomly or not at all. hope this helps thanks and Godbless
Nov 06, 2008 | Kitchen Ranges
How to replace OVEN BULB on Maytag electric range CRE8600CCE here is a link to your oven and it is shown in an exploded view. You will need to unscrew the cover from over the light bulb and then unscrew the bulb to replace with same. Hope this helps..
Sep 23, 2008 | Kitchen Ranges
LG LRE30451SW range
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
Jul 19, 2008 | LG LRE30451ST Electric Kitchen Range
How do u replace the buld in oven
Try unscrewing the cover.
Grasp the glass cover and twist it anti-clockwise.
Oct 27, 2007 | Stoves 1100ESIDLa Electric Kitchen Range
Belling DB90 Electric Kitchen Range Logo
789 people viewed this question
Top Belling Kitchen Ranges Experts
John Tripp
John Tripp
Chris Hall
Chris Hall
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
