Question about Hotpoint Aquarius WMA42 Front Load Washer
Washing powder compartment is filling up with water
4 Suggested Answers
SOURCE:
barkencoa
  • 3463 Answers
SOURCE: where ecxactly do you put washing powder and stasoft
Washing powder should go in the right hand side compartment, if it is not going down, then check that water is coming into washer.
Conditioner should go in the smallest of the compartments.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
skyblue67
  • 71 Answers
SOURCE: where do i put washing powder in hotpoint aquarius
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Posted on Jul 18, 2009
beltronic205
  • 1479 Answers
SOURCE: My machine is continually filling up with soapy water
This sounds like the drain hose is 1st too low next allowing sink waste to enter the machine , you should check this.
Posted on Jun 01, 2010
My aeg lavamat 73620 fills water in the wrong compartment. How do I take out the powder-dosing unit to clean it?
with all the machines ive had you pull it out and lift it up at the same time, then give it a good wash when you put it back you have it upright and slowly lower it as you push it in, don't try and force it.
Nov 22, 2014 | AEG Washing Machines
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing powder compartment fills up with water
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
Jul 13, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
Where ecxactly do you put washing powder and stasoft
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bad bosch
The grey sludge may be due to incorrect soap powder (use only front loader) or excessive powder use. Minimise the powder use and insure you do a very hot wash once every 4 weeks to break down powder that may be building up.
Regards Sam
Apr 15, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Water not getting to powder dept
SMALL SPRING HAD COME LEVER THAT IS CONNECTED TO WATER RELEASE VALVE , RECONNECTED SPRING AND EVERYTHING SEEMS TO BE WORKING OK .
Oct 05, 2008 | Hoover H130E Front Load Washer
Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Dec 12, 2007 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
