Spa starts up ok then a couple of minutes later the breaker trips, will not give a temp readout either.
SOURCE: New set up
Do you have power at outlet? If yes, check for 120v at control pack (follow cord to terminal board ). If no power at terminals and gfci on cord won't reset then power cord is defective. Replace
SOURCE: hot tub breaker tripping after shorter and shorter
Breakers can grow weak---replace with new breaker.
SOURCE: I have a Sundance Spa that has started tripping the breaker
It is unlikely the Breaker is BAD, that just doesn't happen. To trip a breaker there MUST be an Overload, or a Short circuit, that's it. You will have to use a meter an troubleshoot the system. Something is very wrong..please use the links below to troubleshoot and repair. Please Be careful.
http://spababes.com/heaterhelp.html
http://www.spadepot.com/spacyclopedia/spa-heater-element.htm
http://www.poolandspa.com/page596.htm
Testimonial: "Looks like this info may save me a service call. Many thanks for the answer and the links."
