Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
I have bought a samsung 2233sw moniter.when i switch my pc on,it says check signal,although have connected it properly.I hav gt 9600 graphic card.Shud i connect my moniter to cpu or to the graphic card.please help me.My number is 09949600900,if any one can slove this please call me,r reply it here.
    Brigadier General:
  • 7,191 Answers
HI,
You should connect the monitor to the graphic card.
Posted on Jun 29, 2009
Samsung syncmaster 2233sw driver for windows 8
I would make sure my video drivers adapters are up to date. Use windows update to automatically set the proper driver to the display and to your video adapter.
Mar 24, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
Ok, I changed my video card ( hp: p6230f) I still have no signal in your opinion would you go with monitor failure or motherboard? I have also checked all connections. Soon as I turn it on it scans reads...
1.If your display come during start up windows then its problem with graphic settings.
2.check moniter with another pc if its work on that pc then its your card problem.
In the case of 1 you have to go in safe mode and change the graphic setting.you have to change frequency hertz from advance setting to 60hz or 75hz which is mostly compatible with all moniters.And restart pc.you also check display driver correctly installed.
in the case of 2 problem change card or connec it with built in vga card and check your graphic card with another pc.you should find what is problematic by follow these steps.
Jul 13, 2011 | Computers & Internet
I AM FROM INDIA I RECENTLY PURCHASED AN AIRTEL DTH HD VERSION, SINCE I HAVE A SAMSUNG LCD MONITOR (SYNCMASTER 2233sw) WHICH SUPPORTS FULL HD (1920X1080). MY MONITOR RUNS FULL HD WITH DVI CABLES OF...
Hi gurmeet,
What I suspected from your description of problem is that there is some kind of compatibility issue or content protection when you plug in an additional HDMI to DVI converter.
I am also using an Airtel HD connection, though however, I wouldn't need any kind of converter because I am directly connecting HDMI cable to my LCD and it works like a wonder. I set up my box output resolution to 1080i and there is no display resolution mismatch. Not even at other resolutions.
Airtel is using 1920x1080 resolution in signal transmission, so the possibility of 1079 from there end is ruled out, otherwise, the same problem would have been observed when direct HDMI cable is being used. I hope you understand my point.
Now you might also ask why you weren't able to see this problem when you connect the monitor to your PC graphics card. I would like to tell you that graphic cards are very versatile and does have the capability of 1:1 pixel mapping, so there you wouldn't see any such problem.
read this link for more http://www.hdtvsupply.com/hdtodvico.html , where a person is able to match resolution using a similar converter.
I believe the converter you use isn't able to do 1:1 pixel mapping and is actually downgrading the resolution which your monitor is not able to support.
You can try out other resolution type from the STB and if you still see similar problems, then you may need to get an alternative converter.
Follow these steps to change the STB resolution type;
Enter the Menu from STB remote -> scroll to 'My Settings' -> Enter 'System Setup' -> 'HD Setup'. Here you change to a lower resolution and press ok from remote.
Sep 22, 2010 | Samsung Televison & Video
My Pc just shut down while i was playing a game. i unplugged my geforce 9600 gt's power and my pc worked again, but without graphics. what is wrong with my graphics card???
The problem that caused the PC to shut off is the GForce graphics card is drawing too much power and the switch mode power supply was overloaded and shut down.
Check the switch mode power supply's wattage, if it is around 300 to 400 watts, it maybe be too low. You most likely need to get a higher wattage switch mode power supply, especially if you added more RAM, disk drives, DVD drives etc. to your PC after the initial purchase of the PC.
Feb 12, 2010 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Want to use samsung 2233SW LCD monitor as TV
Yes you can, if you has PC desktop, plug your lcd to it. change LCD resolution from your PC.
-- Right Click on desktop
-- Click properties >> click settings tab
-- You will see Screen Resolution, change to the lowest (800x600)
-- Nnplug VGA cable from PC
-- Now plug the cable tou your TV Tuner.
Feb 08, 2010 | Samsung SyncMaster 2233SW Monitor
My screen only shows color stripes when i turn it on. Is it a graphic card problem?
It can be a graphics card problem as this issue comes when there is no signal to the Monitor from the Graphics Card. Other issues might be damaged cable connecting the monitor to the CPU or when the graphics card is not properly inserted in the motherboard.
Feb 01, 2010 | XFX GeForce 6200 Graphic Card
Second monitor detected but no signal?!
Try holding the function key ( fn) and pushing the F4 button. This very well may fix your problem.
Sep 22, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Samsung 2233SW Startup problem.
I finally got myself the solution of my samsung lcd monitor 2233sw.
The monitor has dvi D input, so I guessed I just had to plug the d-sub cable to the monitor as well, and it worked well so far.
Jun 12, 2009 | Samsung Computers & Internet
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
