Although the rice concept is a good idea, it is unlikely that it has aided in the evaporation of all moisture in the unit. I have fixed a number of 'dropped in water' devices (incl an IPOD nano) and I have followed the same process:
- take the unit apart
- remove battery, clean bat and charging terminals - remove any connector (document where necessary) and leave out in open air to dry (or use a hair dryer on low setting / under a lamp). - clean all connectors with rubbing alchohol. In your case, pay close attention to the cable that supplies the screen and make sure the male and female ends are dry and clean. Also locate the backlight and see if there is any moisture around it.
Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. So grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is merely wet and there is a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
Don't Panic. Your phone will probably not be too damaged if you right away take it out of the water. While it's in the water, immediately take it out.
Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
If you have a GSM carrier, remove your SIM card. Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
Dry your phone. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes. Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice. It may be found under a brand name such as the "BHEESTIE Bag™" "DRY-ALL" "Damp Rid" or "Dry Right".
Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
Test your phone. After you have waited a day or so, make sure everything is clean and dry looking and re-attach the battery to the phone and see if it works. If your phone does not work, try plugging it into its charger without the battery, if this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
Take the phone apart If your phone doesn't turn on at all. Try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work go to the professionals.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Ok. What let you slide content and do so many things through touching the screen of your phone is the "capacitive touch screen" embeded on the phone itself has shorted out when it felt in the water (bear in mind that it functions through electricity that continously runs through it. You should contact somebod who knows how to replace it. Good luck
How long has it been since you dropped it in water? Sometimes you can let it dry for a few days and find that it works fine again. Sometimes, the water corrodes the circuit boards and you'll lose some or all functionality. If it continues to not work, take it to an Apple Store if you have one close by. They may or may not choose to replace it under warranty. You can also try calling AppleCare (1-800-275-2273 in the US) FYI, it's better to not lie about accidental damage. They usually have ways of knowing about liquid damage. Good luck!
your going have to take the phone apart and put all pieces in bowl of dried rice let it stay for at least 24 hours re assemble unit and everything should be okay
UGH! Sorry to hear that. You could try the old Bowl of Rice method, where you place the phone inside a bowl of rice, or inside a ziplock back full of rice, and then leave it there for a couple of weeks. (the rice is UNCOOKED!!!) Hopefully, that helps. If not, your phone might be toast. Check and see if you have insurance with your carrier, and whether they insure against water damage.
According to their website, leapfrog says that immersing your device in water will void the warranty. what many people do with their iPhones is put them in a bowl of dry rice, maybe this will help?
Have you tried putting it in a bowl of rice for a week or so? I haven't experience this myself but if a Wii remote is anything like an iPhone it should dry out all the water. Putting new batteries in it after the bowl of rice would be a good idea too. I hope this helps
You can put it in rice, the rice will drain the water out this is how
(1) Remove it from the water immediately.
(2) Turn the iPhone off.
(3) Dry it off with a towel
(4) Grab a bowl and fill it with uncooked rice or you can also put your phone in with a bunch of silica packets.
(4) Put the phone in the bowl of rice and cover it up.
The purpose of this is to draw moisture out of the phone as quickly as possible. You can also let it air dry, however the above methods will work faster.
NOTE: Do not dry it off with a blow dryer as this could melt the circuit board and other parts.
Leave your phone in the rice for at least 24 hours and preferably 48 hours. Hopefully, after 24 -48 hours the phone will have dried out, the logic board wasn't damaged, and hopefully you can turn your phone on and it will work. If not, your next option is to see if it can be repaired without costing you an arm and a leg.
dont turn it on. and if it is on turn it off. put your phone in a bag of dry uncooked rice of r a minimum of 2 days depending on how long it was submerged. i would go a week to be safe.
useually unrepairable but take the back off then remove battery and sim then use a hair dryer to try and dry out the moisture sometimes it works depends on how much water damage is in the main board
