SOURCE: brake and ABS warning lights on, trac off on.
You may have a bad abs controller. You need to get the code for the abs light from a shop or auto parts store.
SOURCE: 2006 Chevy Aveo won't start in cold weather
go to an auto parts store and get an electcic dipstick heater . remove your oil dipstick after parking car for the night.install electric dipstick preferrably while engine is still hot plug it in at night .this will
help keep the oil warm and also the block after car starts unplug heater remove it and install original dipstick. this is the easiest to install but there are also block heaters
SOURCE: 2004 A4 1.8T Brake Lights Remain On After Car Is Parked
Sounds like your brake light switch is on its way out. Its a simple fix and a cheap part. It will need to be done immediately as not only can the lights staying on drain your battery but it can also cause lack of power and not put the brake lights on when braking. The switch is operated by the pedal itself and requires the drivers underdash trim to be removed. With this off the switch can be accessed and replaced. If you can get a vehicle technician to fit it, do so, as they are quite fragile and new switches can become useless if fitted incorrectly. Good luck
SOURCE: !995 Audi a6 Quattro only cranks wont start.
dealer only ,factory immobiliser is cutting in, try the spare key and if it doesnt start call the breakdown truck to take it to dealer
