CPU fan not detected
When starting my computer, ''cpu fan not detected'' appears and I need to press F1 to continue. My fan was very noise and now it obviously is not working. What should I do? Thanks!
  • 59 Answers
Dear User,
pl check your cpu fan working properly or not when pc start.
when pc shut down pl check fan moving by our hand and smooth moving or hard moving pl check it.
Your solution is change cpu fan.
Regards,
Ravindra Shah
Posted on Jun 29, 2009
  • 555 Answers
Try to check the connectivity of your fan if it is still working or not. Also try to check  the power if theier is a electricity supply in the connection of your CPU fan. Else you have to find another fan,.
  • 40 Answers
Replace ur cpu fan...... if u hv a problem with SMPS the fan which u can see at the back of ur cpu do replace it.. this SMPS provides all the power requorements for ur CPU
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Have a desktop windows 8 model 110-023w I get message about Fan Not Detected and have to hit F1 to boot
This is self-protection message from the BIOS/CMOS. It is stating that it is not detecting the presence of a CPU fan (no rotation). Thus it is not starting the processor to prevent overheating. If you F1 the system you will force the processor to start, it will overtemp, and then shut down automatically anyway. You need to check the CPU fan and repair.replace as necessary.
Jan 11, 2016 | HP Pavilion Computers & Internet
When i turn on my hp all in one computer,it's telling me cpu fan can not be detected
Hello user...you are receiving this message at start-up because, in your bios system settings, "run fast diagnostic test" is enable...CPU fan is like a computer fan but attached with the cpu to cooled the cpu so that the cpu will function properly so as the computer...perhaps there is a problem with the fan, so its not running when the computer starts. This may harm your CPU, as a result may blow the circuits in the motherboard and eventually your computer will crash....for a technical advice, you may want to visit the nearest PC repair shop and change the cpu fan..
Jun 23, 2014 | HP Mini 1000 Netbook
Asus p6t se
harry up change cpu fan or" pemanent damage your cpu if fan is off.
May 30, 2012 | ASUS P6T SE - Motherboard - ATX - iX58 -...
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
I HAVE NOT LOOKED INSIDE MY COMPUTER, BUT THE FAN BEGAN MAKING A LOT OF NOISE A MONTH AGO. TODAY THERE WAS NO NOISE AND A MESSAGE CAME ON MY SCREEN SAYING "FAN FAILURE- PRESS F1 TO CONTINUE. MAY I USE...
First, if the CPU fan is not spinning properly, you should NOT run the system. The fan needs to be replaced.
If the fan is running normally, you may boot by pressing F1.
Before replacing with a new fan, you can first try re-seating the plug for the fan in your computer. The fan's plug may have been bumped or loosed. Re-seat the plug located at J1F1 as shown in the picture below and be sure that it is properly connected.
Hope this helps.
Sep 28, 2010 | Computers & Internet
Cpu fan
There are usually more than one place to plug in a CPU fan. Only one of them is actually for the CPU fan, and monitored by the system BIOS. Make sure your fan is plugged into the right connector.
Jul 18, 2009 | Zalman Tech (CNPS7700CU) CPU Fan
Cpu fan
It isn't detecting your fan as the fan may be dead or the sensor is dead. Both are not repairable but cheaply replaced and fixed with a new fan. The cost of the replacement cpu fan is not that much compared to a cpu. So don't try to make it last a bit longer by hitting the f1 to continue. That will catch up with you pretty quick.
If you want to double check you need to look at either the cmos setup section of a system monitoring software and check to see cpu fan speed and cpu temps. You may not see the speed but you should see the temps. If the temp is getting over 55-60 or more shut down and go get the fan. It's dead. If you see the rpms showing then you might have a motherboard problem.
However I would say you have a dead fan. Replacements are $5-15 and you need to just crack the case and pull the old one and put in the new one. You can take it to a tech but they will charge you to check it out again and then ti replace the fan and some shops will insist on new heat sink etc (those don't ever ever wear out or go bad at all)
Jul 18, 2009 | Porter Cable 75182 Variable Speed Router...
CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Feb 07, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
790 people viewed this question
David Payne
David Payne
