Question about Canon NP 6050 Copier
Cost 6050 duram cost and 6050 xerox cost new
  • Canon Expert
  • 1,326 Answers
The drum cost more then the copier is worth.... Yoy may be able to switch the drum ends and move a mark to the other side and it may not show up...
Posted on Jun 29, 2009
XEROX COPIER PRINTS BLACK PAGES
The toner is probably not closing correctly. You probably have a mess inside the machine. You will probably need to take the toner cartridge out and clean the areas affected.
May 20, 2014 | Canon NP 6050 Copier
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I want to know exact wattage of CANON 6050 xerox copier
on the model tag it gives you voltage and amps. multiply thes 2 numbers to get watts. to be more exact you need to check voltage at the source and take an amp reading while copier is running. Or if you have a watt meter that would be easiest.
Mar 23, 2011 | Kitchen Ranges
IT WILL COST US $394.00 TO FIX OUR XEROX PHASER COLOR 6120'S FUSER UNIT including LABOR. IS IT WORTH DOING AT THIS COST OR WILL IT BE BETTER TO BUY A NEW COLOR PRINTER?
Anything over 100 dollars for this unit is too much. You can purchase a new one for $450, there is no need to spend the ridiculous amount on the fuser.
Jan 30, 2011 | Xerox Phaser 6120/YN Laser Printer
What is the cost price of canon xerox model no.6050
Not much its too old model and there is verry small stocks of spare parts.
Rather buy new Canon iR3225N digital copier.
Sep 05, 2010 | Canon NP 6050 Copier
How is IR400 xerox m/c and whatis price of new m/c
in india canon photo copier is best choice and copy cost also very less compair any other brand
and u want m/c cost call this number
91-92462704050. hyderabad ap
Jun 27, 2010 | Office Equipment & Supplies
PRICE IN MUMBAI OF CANON 4050 XEROX
pleace buy canon ir series only
Oct 09, 2009 | Canon NP 6050 Copier
About my business...
Xerox DocuColor 3535 RC With Xp12 Feary Is the best for color & canon IR 6000 For Black & White
is Best For all.
May 24, 2009 | Canon NP 6050 Copier
Service manual
you can go up on the web. look up INTRAVIA COPIER MANUALS, THEY HAVE MANUALS FOR ABOUT EVERY COPIER dont know the cost they are in buffalo new york, good luck
Jan 29, 2009 | Canon NP 6050 Copier
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
103 people viewed this question
old marine
old marine
