Question about ASUS Eee PC 2G Surf Notebook
Disabling the user password without logging in
    Genius:
  • 1,550 Answers
You cannot disable the user name
password request before logging in
else can go in a diffenent user
Posted on Jun 29, 2009
Identity problem Account disabled.
E-mail accounts are disabled after so much time has past without the user logging in. First try giving email id and then clicking on forgot password option. They will either send you a temp password to get into your account or they will ask you secret questions used when you set up the account.
If that does not work then follow what they say and create account and use the same email and password of the original. It might rez it. Or just make a brand new account and log in once in awhile so it does not become disabled.
Apr 17, 2015 | Computers & Internet
Tip
Allowing Network Access with Blank Passwords with Vista
Although you can log in locally without a password, by default, Vista does not allow network users to access the computer without a password.
To change this setting:
Run gpedit.msc
Go to Computer Configuration / Windows Settings / Security Settings / Local Policies / Security Options
Double click on Accounts: Limit local account use of blank passwords to console login only
Disable this option
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Enter system password
Which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
or
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window.
Click the user for whom you want to disable the password login.
After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer."
Click "Apply."
A dialog box will prompt you for the password.
Enter the user's password to authorize the changes and press "OK."
Reboot your Windows XP computer.
When it shows the list of user profiles, click the user whose password was disabled.
You should be able to log in without a password.
Jan 22, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
Aug 04, 2013 | Computers & Internet
How can renew my id and password
Click "Apply."
Reboot your Windows XP computer. When it shows the list of user profiles, click the user whose password was disabled.
also
Click the "Start" button.
Double-click "User Accounts."
Select the user account you wish to change.
Select "Change My Password." If you wish to remove the password, select "Remove My Password."
also
Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password.
Just click In New password and Confirm new password, type the new password by just clicking, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer.
You cannot change your network logon password in User Accounts.
To change your own password, press CTRL ALT DELETE and then click Change Password
Jul 14, 2013 | Computers & Internet
Change password
Click "Apply."
also
also
Jul 11, 2013 | Computers & Internet
How do i delete password on hard disc drive
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window. Click the user for whom you want to disable the password login. After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer." Click "Apply." A dialog box will prompt you for the password. Enter the user's password to authorize the changes and press "OK." Reboot your Windows XP computer. When it shows the list of user profiles, click the user whose password was disabled. You should be able to log in without a password.
also Click the "Start" button. Double-click "User Accounts." Select the user account you wish to change. Select "Change My Password." If you wish to remove the password, select "Remove My Password." also Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. Just click In New password and Confirm new password, type the new password by just clicking, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
Hope this helps.
Jan 23, 2013 | Acer Computers & Internet
I am trying to log into my router to change the NAT type, So i reset the router as the default username and password. Now when I click on the router in the start menu, it switched the router off? I am...
You do not need the software that comes with any modem:
Reset the router:
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the reset button on the rear panel of the router.
1. Press and hold the reset button until the Power LED turns red (about 6 seconds).
2. Release the reset button and wait for the router to reboot.
To log in to the modem router:
1. Type http://routerlogin.net or http://192.168.0.1 in the address field of an Internet browser.
Enter admin for the user name and password for the password, both in lower case letters.
NAT automatically assigns private IP addresses (10.1.1.x) to
LAN-connected devices.
? Enable. Usually NAT is enabled.
? Disable. This disables NAT, but leaves the firewall active.
Disable NAT only if you are sure that you do not require it.
When NAT is disabled, only standard routing is performed
by this router. Classical routing lets you directly manage the
IP addresses that the DG834G v4 uses. Classical routing
should be selected only by experienced users*
? Disable Firewall. This disables the firewall in addition to
disabling NAT. With the firewall disabled, the protections
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2010 | NetGear DG834G Router
Log-in security in windows 7
1. Goto Start->Run (or press Windows+R) and type "control userpasswords2" (without quotes).
2. Look for "Users must enter a user name and password to use this computer", it's near the top.
3. Uncheck this option and apply.
4. You may need to enter your password to confirm changes.
Remember to rate my solutions! If you have time, drop a testimonial too - they really make my day. :)
Mar 30, 2010 | Microsoft Computers & Internet
I want to disable user log in on an older computer atx micro atx cpu 133MHz what jumpers will disable the user log in?? after boot it want the user and password and this machine was bought without...
Hi walkertexr
You can clear the cmos, which will reset the password on the motherboard, by the following:
  1. Turn off the system and unplug the AC power.
  2. Remove the ATX Power Cable from the Connectore PWR2
  3. Locate the JP14 and short Pins 2-3 for a few seconds
  4. Return JP14 to it's normal setting by shorting pins 1-2.
  5. Connect the ATX Power Cable back to connector PWR2
  6. Plug in the ATX Power Cable back to the System,
That should do it. Here's a really bad picture but it should give you an idea of where the jumper is.
Good Luck,
Mark
Nov 18, 2009 | AOpen Computers & Internet
ASUS Eee PC 2G Surf Notebook Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
