Question about LG X-Note LM50 Notebook
I have lost the disk for 802.11bg wlan
I only need to activate the wireless device, any ideas????
  • squidworth69 Jun 29, 2009
    im using xp. i dont have a laptop
  • 326 Answers
Http://www.notebook-driver.com/lg/lg-notebook-lm40lm50-driver/
theres 2 lan drivers there but only for xp, let me know if your using vista
Posted on Jun 29, 2009
  • 1 more comment
  • mark hudson Jun 29, 2009
    sorry, activate. if the drivers installed then there should just be a switch on the laptop to switch it on, ill see if i can find a manual
    your manual
    let me know if i read this problem completly wrong :)
    youve posted this as a notebook laptop lg x-note lm50 is this driver for your desktop?
I have a level one wap 0004 wireless access point. I also have a panasonic blue ray player that i am trying to connect the adapter too. The blue ray player has an ethernet connection. The 2 are now...
so, depending upon if you are connecting it with a cable or wireless it is a little different. Wireless sometimes has wps button too for a quicker config/connection.
I suggest you Check the manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiUnI_205zTAhUE7YMKHfM-Cv4QFggaMAA&url=http%3A%2F%2Fdownload.level1.com%2Flevel1%2Fmanual%2FWAP-0004(EN).pdf&usg=AFQjCNGJRGXedGyKrPDAD2yOSP0CIN39wA&sig2=Rq3EoRlhyzd_LmCLkg8VwQ
Often you go to the url of the routers IP address but you need to know that and the default username and password for administrator, which BTW you may wish to change so only you know it.
Apr 11, 2017 | Levelone WAP-0004
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
I have two laptops one wont connect to the internet explorer web
Very vague problem description.
Check the WGR614 settings, you may have activated the MAC address filter for wireless that allows only devices with known addresses to connect to the router.
Next is DHCP settings, is your router set up to provide IP addresses to devices (recommended) or is it set to static IPs? Your laptop must match this in its own network settings.
What about WLAN security? Is your laptop able to match the security settings of the router? Some older wireless devices do not support advanced encryption (TKIP, AES, ...) or any protocols beyond WEP.
Also very common: is the WLAN radio activated on your laptop? Sometimes success is just a gentle push away on an innocent looking switch at the laptop's edge.
Feb 07, 2010 | NetGear WGR614 Router
I?m unable to detect any wireless networks, because the WLAN adaptor hasn?t yet been activated. There is a specific ?hotkey? (function+F1) to enable the WLAN adaptor but the keyboard doesn't work anymore...
Hello shge2dope,
The wireless lan can be activated (enabled) from the control panel as follows:
•Click Start (lower left-hand of screen)
•Select Control Panel
•Select Network and sharing Center (might be called just 'Network')
•Select the wireless lan adapter and enable it
* Another way might be to select the WLAN icon in the lower right-hand corner of the screen. Then right-click and select the option to enable it
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | Medion MD-40954 Notebook
3COM WLAN not working
Might be time for a new device. My favorite is the LinkSys brand.
Dec 26, 2009 | 3Com OfficeConnect Wireless Router
WLAN Problem
Remove battery and disconnect power.
Hold down the power key for a minute.
Reconnect battery and power and start the computer. Try using the wireless button again. It should work now.
Mar 14, 2009 | HP Pavilion dv4-1140go Laptop
Does my HP s7750 have wireless internet connection. if so how do i turn it on or if not do i need to buy a wireless usb adaptor
check the box that the machine was packed. if you find a antenna, then, your machine have wireless LAN.
to set up the Wireless
1 Click the Windows Start Button on the taskbar.
2 Type Device Manager into the Search box, and then click Device Manager to open
the Device Manager window.
3 Click Network adapters. Your WLAN device should be listed here. The WLAN
device may include the term wireless, wireless LAN, or 802.11.
4 Click the Windows Start Button on the taskbar.
5 Type Network and Sharing Center into the Search box, and then click Network
and Sharing Center
to open the Network and Sharing Center window.
6 Click Add a device to the network and follow any onscreen instructions.
For more information about setting up a wireless network:
 Click the Windows Start Button on the taskbar, click Help and Support, and
then type Setting up a wireless network into the Search Help box.
NOTE: If no WLAN device is listed, either your computer does not have an integrated
WLAN device, or the driver for the device is not properly installed.
Feb 26, 2009 | HP Computers & Internet
Wlan disabled
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
WLAN Problem
Hi, A couple of things you can try: 1. In your Device Manager, expand your Networking Adapter, right click on your WiFi and click on enable; 2. Some notebook/laptop models have a hard swtich on either the side or the front to activate the radio of the WiFi; 3. Verify that your WiFi drivers are installed and that it has no red or yellow markings (Device Manager); 4. If you are using plug-in (USB or PCM card), verify that they are plugged in snugly.
Sep 25, 2007 | Computers & Internet
LG X-Note LM50 Notebook Logo
95 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
