Question about Epson Stylus C86 InkJet Printer
My Epson stylus C86 will not print even though I have put 4 new cartriges in and cleaned the heads
  •  Robert Allocca
    Robert Allocca May 11, 2010
    Need more info. Epson carts or Generic?? What if any message do you get.
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Check.......removable tabs removed, cartridges installed [they Click when pushed down]. Did you get a Clear test pattern? If all the above have been done and you still have a problem, it's time to call Epson tech support
Posted on Jun 29, 2009
How do i reset Epson c84 ink cartridge
I am finding some truth to comments about unused ink cartriges In the
> Stylus C84 registering as empty when they still sound full(colors go
> empty even when you just print black). I am wondering how safe it
> would be to use an chip resetter on a cartrige without refilling it and
> allowing it to print until it truly is empty. Would there be a risk of
> some air getting injected into the head (when the cartrige runs out),
> thus ruining another printer (already went through one printer and got
> it replaced through warranty, but I think that was just from leaving
> the printer unused too long -- I don't have a resetter right now).
Jul 13, 2015 | Epson Stylus C86 InkJet Printer
Put in new ink cartridge and every other line is 1/2 readable?
Epson's software will let you clean your print head. Inkjets have a problem with drying out and clogging. Access your Epson monitor software and clean the print head.
Sep 15, 2009 | Epson Stylus C86 InkJet Printer
I have an Epson Stylus Photo 1800 printer. Though I have checked and cleaned the heads there is always a faded light line about a half inch wide on each 8x10 print. I am new to printing and did not...
Try running a clean/alignment on your printer. There should be a utility program bundled with the software that will perform this function. Chances are the line is there due to one of the print heads being out of alignment.
Aug 21, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus C86 will not print clearly in black
No doubt this is the result of some clogged print nozzles in the print head.
I have a C86 myself, and have ignored it for about 3 years. There were full cartridges in it, and now they are full of sludge instead of inks. The print head itself is probably full of solid ink (dyes, actually) too.
I love this inexpensive, easy-to-use printer. It is quick, quiet and inexpensive to run, and I have no desire to purchase a replacement.
Go to Ebay, look for the Dr.EpSun Majic Inkjet Flush Store (link should work)and locate the flush for this printer - with shipping about $25 US.
They claim a 100% Money-Back Guarantee if it doesn't work. I'm going to buy a kit myself right now, hope it works - I do miss this printer PLUS it works on MS VISTA with no added drivers!
Jun 06, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 - prints faint magenta even though ink levels are in a normal printing range - does not print anything or a barely seen magenta line during nozzle check and heading cleaning
You probably have a slowly worsening clog building up in the Magenta nozzles. It's also possible that your ink is reaching its end of life which, given the age of the C86 is entirely possible, especially if you are refilling or using a CIS sytem with your printer.
If it's a clog issue you can try soaking the parking pad with a mildly ammoniated cleaning solution (original Ammonia windex is good for this) or even distilled water. Leaving this with the printhead parked above it allows the solution to wick up into the nozzles and break down any clogs in the printhead.
If the problem is ink age though you will probably want to carry out the solution above AND replace your ink with a fresh solution. A CIS will need a thorough flush to remove any algae and cloggation residues before you use it again or you will just reintroduce the problem.
Hope that helps.
Martin
May 27, 2009 | Epson Stylus C86 InkJet Printer
Bought a used c86 epson off e-bay and it wont
that means that the heads must be replaced or the ink pump is faulty. It is not even worth the repair.
Call the Ebay seller and have your money refunded.
Apr 16, 2009 | Epson Stylus C86 InkJet Printer
I just bought new ink and nothing prints clearly
If it hasn't printed anything for a couple of years then the print heads will be severely clogged with dried ink. Epson recommends printing a page or two every month to keep the heads clear. You need to try cleaning the print heads, its unlikely that one or two head cleans will clear a badly clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink, have some new ones ready.
If you need to know how to do head cleans & nozzle checks, the user guide can be downloaded from Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVFHuU002FlmukU002FlwLFmittYG0bE9gMlZoUifYkU003D
Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus C86 InkJet Printer
Printer doesn't print
Check this FixYa thread:
http://www.fixya.com/support/t495440-epson_stylus_c86_print
You need to see if the waste pad is full. This could be your problem.
Feb 11, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
