Question about Kodak EasyShare M853 Digital Camera
Kodak m853 pictures wont save to sd card
4 out of 5 pictures that i take with this camera dont save to the sd card. the card is fine as i have tested it out on other cameras. after you take a picture and try to review it the camera goes a bit crazy and then the image ceases to exist
  • ryaneld Jul 05, 2009
    not the card. have tried several sd cards and they all act in the same way. the problem is with the camera.
  • 34 Answers
Try to format the card in the camera. Afterwards, try taking pictures again.
Posted on Jul 05, 2009
  • Sol Ocampo Jul 05, 2009
    please format the memory card in your camera.
    to check on the steps on how it can be done, please go to kodak.com/go/manuals or you can also try the chat support so that they can give you the step-by-step procedure
  • Sol Ocampo Jul 07, 2009
    please try to remove the card and format the internal memory. check if pics are saved in the internal memory.
    if this is working, try to format the card as well.
    take a picture and check if it will work.
Kodak easyshare troubleshooting
When you have removed all the pictures on the card next time, format the card. this will clear out all the pesky little bits that haven't been erased yet. This should speed up the card again.
Nov 29, 2013 | Cameras
I only have 7 pictures on here. I've tried taking the memory card out but still get the message that the memory is full. Don't know what else to do. Help
Check whether the sd card has the 'lock' switched on. Its a physical slide button on the side of the sd card which may sometimes cause this error. Thumb me up if I helped. :)
Jul 02, 2011 | Kodak EasyShare M853 Digital Camera
If the camera says the internal memory is full and won't allow me to take any more pictures, do I need to get a new card reader?
Your camera has only 32MB of internal memory, out of which only 13.5MB only is used for picture storage, which allows you to save only a few pictures. If you need to shoot more pictures you need to buy SD or SDHC cards or micro SD cards. If you buy micro SD card, then you also need to buy an SD adapter. SD adapte is very cheap, usually less than a dollar. The maximum size SD card you can use in Kodak Z915 is 32GB SDHC card. SD card sizes are available only upto 2GB. SDHC cards goes from 4GB to 32GB. Again these cards are rated based on their speed classes. It is preferable to buy Speed class 6 and above for good video recording. With higher speed class, speed increases. If you want to shoot pictures faster then you need higher speed class memory. Price of the card increases with the speed class. You can buy speed class 2, 4, 6, 8 or 10.
If you want to download your camera manual, try the following site:
http://resources.kodak.com/support/pdf/en/manuals/urg00995/Z915_xUG_GLB_en.pdf
Jan 14, 2011 | Kodak EasyShare Z915 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
    I have a new memory card. I cant get pictures
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Oct 27, 2009 | Kodak EasyShare C330 Digital Camera
    Pictures are pink with lines
    The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
    Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
    Jul 02, 2009 | Kodak EasyShare M853 Digital Camera
    Kodak M853 error message
    My first inclination was that maybe the lock on the side of the SD card was on but after you mentioned that it worked in your mom's camera, I don't think that's the case. You may want to check that though. There's a little switch on the side and just make sure that it's switched to the "unlock" side.
    The only other thing would be to format the memory card. When you do that, you will lose all the pictures on it. So, if it happens to work in ***********'s camera, I would transfer the pictures you already have saved on there and copy them to a cd before formatting the memory card.
    In order to format your memory card, press the menu button, then go into the setup menu. There should be a list of settings. Scroll down to the format option and choose to format the memory card.
    I hope this helps :)
    Jun 12, 2008 | Kodak EasyShare One Digital Camera
    M783 CAMERA
    buy 9.99 kodak usb charger from best buy,etc-known issues ww/kodak m series not charging right-use wall charger-buy sd memory card reader to download photos w/no problems
    May 21, 2008 | Kodak EasyShare M853 Digital Camera
    CMT2008
    I believe the picture size you're using is not the maximum of M853 which is 8MP, otherwise you can take fewer pictures - like for 4 or 5, depending on the scene complexity.
    Your camera has 16 MB internal memory. The lower MP you use (menu> picture size), the more pictures you can store.
    If you want to take more pictures, use a memory card. the cam is SDHC ready - been tested to work up to 4gb. may even work with 8gb.
    Dec 26, 2007 | Kodak EasyShare M853 Digital Camera
    Kodak EasyShare M853 Digital Camera Logo
    115 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
