Question about Samsung 19" 720p Flat-Panel LCD HDTV
My picure fades to black when i turn my tv on and makes a hissing sound but the sound is ok.
Here is a possible solution, http://techreport.com/forums/viewtopic.php?f=37&t=62360 I opened mine up and it appears that four of my capacitors have a shot electrode.
Posted on Jul 24, 2009
Are ther advanced setting for my samsung pn64d8000 tv?
Unfortunately, the answer is no. Samsung pn64d8000 TV does not have any advanced settings.
I hope this is clear. Please let me know if you have any more questions about this TV.
Regards.
Apr 30, 2011 | Televison & Video
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Blue screen no picure good sound
Check your video inputs or cables for wear from the signal your using. Does it do it on other inputs (DVD, game etc??)
Sep 05, 2009 | Sony KP-51WS500 51" Rear Projection...
94 s10 chevy 2wd brake pedal fades to floor before stoping
Might check around the big black round muffin shaped chamber adjacent to the master cylinder for a loose vacuum hose or crack therin; the hissing sound seems likely to be the air rushing in as you loose the vacuum that supplies the power to assist your braking effort (power brakes)---as this goes, so goes your peddle until it reaches the actual piston pushing the brake fluid (which should be firm like with non-power brakes).
...maybe have an assistant push on the peddle while you listen with a piece of hose or a stethescope to find the leak (or I suppose the power unit diaphragm could be shot/leaking--hence replacement), but since you said after bumpy road etc, one could hope for a simple dislodged vacuum hose or fixable crack.
Aug 08, 2009 | 1994 Chevrolet S-10
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Gas fumes
chech the fuel pressure regulator,its black incolor and has a vacuum line to it.It will be in the fuel rail.start the van and pull off the vacuun line, if fuel comes out its bad.
Feb 01, 2009 | 1999 Oldsmobile Alero
Picture fades to black then reappears and repeats fades to black .
Is the sound ok. Yust the Picture. If both dissapear replace power supply board. That is the main big board with the most heatsinks on it. Main power gos from a switch board to main power supply.
Nov 21, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung 19" 720p Flat-Panel LCD HDTV Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
