My hardisk is inserted to the usb ports but it is
My simpletech 120 gb hard disk is inserted to the usb ports but it is not recognized by my computer it is neither shown in safely remove hardware nor in my computers soon as i am inserting hard disk in usb port a dialog box appears which shows that hard disk requires a driver please anyone out there can help me?
  • 40 Answers
U might have received a CD along with the harddisk so install the software which is the driver for ur harddisk
Posted on Jun 29, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Computer won't recognize my simpletech 120 gb external harddrive
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps you
Oct 29, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
My computer won't recognise my 120 gb simpletech harddrive unknown device and driver software not installed
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Sep 14, 2011 | SimpleTech (sti-u2f36/120) 120 GB Hard...
Solve Your SimpleTech (SP-U25/120G) 120 GB USB Hard Drive Blue lights are not on. Windows 7 does not recognize. I think driver is not installed. Pl advice
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jul 04, 2011 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
I have a simpletech harddirve 120 GB. Had it for about 2 years. The blue and red light usually appears and you could feel it run. Now theres no sound or moving parts and now only the red light appears. ...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Nov 10, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
I deleted files from my simpletech 120 gb and now no computers recognize or will open the drive? Do I need to reinstall drivers?
While deleting files your hard drive files also have been deleted so you just re install and try it your probleem may be solved
Aug 27, 2010 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Simpletech 160gb
I would guess you are useing USB.
If correct, try a differant USB port.
The USB port you are useing may not be configured for USB2 speeds.
Sep 21, 2009 | SimpleTech SimpleDrive 160 GB External USB...
The computer does not recognize the Simpletech external hard drive. I plugged in a different external hard drive into the same USB port and the computer recognized it right away. What is wrong with the...
not all usb devices work on all machines
You need to find a driver or ask simple tech what the issue is i had the same issue with My WDC drive Western Digital gave me a driver after emailing them
Aug 13, 2009 | SimpleTech 750 GB USB Hard Drive
Transcend 160GB Portable Hard Disk is not recognized by computer
when you power up the computer press F2 or "del" key to enter in bios then go to usb option and enable usb 2.0 legacy. then save settings .
then check.
some times usb speed make issue so try this.
Also check your usb cable working fine try with other usb cable.
Also check harddisk jumper settings.
If still face problems then you need to repair it.
You shuold take it to service shop becasue you try with 10 computers and all gives same error then your harddisk has hardware issue.
try above solution .
Thanks for using fixya.
Please rate my solution if it helps you.
Jul 20, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
Computers & Internet Logo
167 people viewed this question
Alun Cox
David Payne
David Payne
