Question about Sharp AR-BC260 Color Copier
Remove and replace drum
How can i remove and replace the black drum on a Sharp AR BC260
    Scholar:
  • Sharp Expert
  • 120 Answers
Shut the copier off and unplug it.
Open the left door partially, to free the drum cartridges.
Swing the flap up on the toner/developer cartridge and pull it out
Hold in the drum cartridge body while turning the blue screw at the bottom (?). The cartridge should pop out allowing you to pull it.
Put the drum cartridge on a soft flat surface. I like using a disposable diaper.
Remove the white clip holding the drum rod and put it where it won't get knocked into the twilight zone.
If you don't care about the old drum, grab and hold it. Or hold it by the edge or use a rag before doing the next step.
Carefully poke the rod into the drum from the left hand side using a screwdriver.
Then grab the rod from the right, and pull it out while twisting.
Or move the drum while in the frame to the right, and lift it up and around the foam pad. Then remove the rod.
As they say in the biz, installation is the reverse of removal. Don't forget to use SIM 24 to clear the drum counter. How about setting your registration and black density?
BTW, you do have the replacement kit with a fresh blade, seal and charger don't you? No sense replacing the drum without a new blade. And powder for the drum?
If you want to risk it, just make sure you use a toner vac to clean out the waste auger, without wrecking the charge grid, the mylar seal and the blade. Don't get toner on the blanking lens under the charge grid. I suppose you could use toner to dry-lube the drum. Any further questions please write....
Posted on Jul 09, 2009
  • unkl foddy Jul 09, 2009
    Almost forgot .... to get the rod to go into the left side of the drum you have to wiggle it a bit, best to do this when the drum is in the frame. Wiggle the rod to get into the left inside of the drum, wiggle some more to push it through the left side of the frame. Make sure the groove for the clip is completely exposed out the left side. This can be a problem, you may have to back out the rod slightly and SLAM it a few times, but take care not the scratch the drum, get fingerprints on it, or remove the powder.
    SIM 50-20 or 22 sets your registration, cant remember what sets the black density .... write for info
  • unkl foddy Feb 10, 2011
    Or, you can just replace the whole drum cartridge, AR-C26DU
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Sharp ARC-172M how the drums get out?
open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum out towards you....done.
Apr 21, 2009 | Sharp AR-BC260 Color Copier
I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
Sharp AR-BC260
I would inspect the fuser unit for abraising on the roller or missing and/or broken pauls.
Jun 06, 2008 | Sharp AR-BC260 Color Copier
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Sharp ar-bc260
change the transfer belt, and drums, suggest a whole Preventive Maint.. , part broken in tray 1, that is not enough detail..
May 16, 2008 | Sharp AR-BC260 Color Copier
Sharp AR-BC260 Color Copier Logo
279 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
