Question about Konica Minolta DiALTA Di200 Copier
F36 reset problem - Konica Minolta DiALTA Di200 Copier
  • myzellemedin Jun 29, 2009
    F-36-2 HOW TO RESET
  • 32 Answers
There is a dip switch that changes state, this is because the machine is in shutdown mode due to a fusing unit error, and must be checked over for possible faults.such codes must only be re-set by a qualified tech....
Posted on Jul 04, 2009
F34 nad f36 error bosch washing machine
Check/ clean filter bottom R/H side could be dirty. Sometimes can be hard to remove to clean take it easy with it it can be quite Brittle plastic
Feb 02, 2015 | Bosch Washing Machines
Konica 7020 trouble code 36-1
dear need help to resite l detect value auto adjustment developer konica 7020
Feb 26, 2013 | Office Equipment & Supplies
Electrolux oven error code f 136...what to do?
Hello - Could it possibly be error code F13 or F36? According to my research this manufacturer does not have an error code F136. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and see if the error code clears. If it proves to be ineffective, contact a professional to move forward accurately to properly diagnose the unit.
Nov 25, 2012 | Ovens
Kelvinator F36 oven door glass measurements
you have to get high temp glass or it will shatter
May 24, 2010 | Ovens
My konica 4355 is showing f36-1 error what could be the problem
Fuser Section overheaded (HOT SECTION) can be reset in 25 Mode. If it comes back Fuser needs replacement part(s)
Feb 24, 2010 | Konica Minolta Office Equipment & Supplies
Frig. model# gler642as3.. No power. No light.
Go to http://www.partselect.com/ModelFrames.aspx?ModelID=1107121&ModelNum=GLER642AS3&mfgModelNum=&ManufactureID=4&Selected=ZGBPCQG3&Position=4&mfg=Frigidaire&Type=&Mark=0 the parts you need to check are F15, F33 and F36. F15 is the element. F33 is the High limit thermostat and the F36 is thermal limiter. The most common problem with these dryers when they are not heating is a bad thermal limiter (F36) F33 would be my second guess and the element would be my next. Either one of these could be causing it not to heat. Good luck
Dec 15, 2009 | Frigidaire GLER642A Electric Dryer
I connot remember the pasword to open reset code. it was an accident to ON the switching 2-6. THE PROBLEM NOW IS I CONNOT RESET THE CODE F36-1
I can give you a generic solution.... You did not give a model number. Some are different.... Is it a Konica or is a Minolta based copier???? Try this press the user choise botton then when then the display changes - press the meter count - then press Stop - 0 - 0- Stop. The display will change to Service mode.. That is if it is for your generic Konica Minolta copier.. Good Luck
May 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Konica Minolta DiALTA Di200 Copier Logo
257 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
