Question about Olympus Stylus 720 SW Digital Camera
The lens cover won't close or open all the way.
Two year-old waterproof camera appears to have water leaking inside. The lens cover motor seems affected. It only closes part way, so the camera turns itself off immediately after turning it on. When I removed the battery, it had a few small water droplets on it. After several days of letting the camera dry out, with the battery being recharged, there's no improvement.
  • Obertelli
    Obertelli May 11, 2010
    Saltwater, chlorinated pool water or fresh water?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 11 Answers
Got It! You might try just soaking the camera for a little while like one response said. But I just removed the front face plate. There was accumulated gunk holding the lens cover, and I had the exact same symptoms you're describing. Gently wiped it all clean and presto! all good. You are not opening the camera, just removing the front face. There are three small allen screws on the front and a small phillips screw on the edge.You will need a very small (1.5mm) metric allen wrench (found in common allen wrench sets), and a very small screwdriver for a little screw on the side (found in common micro screwdriver sets). Keep track of which hole each allen set screw came from, they are all different, in fact one appears to be just decoration and has no threads, I just secured it with a tiny dab of all purpose adhesive (Ace hardware brand). Check the tab near the lens goes back in place. Dr. John Christensen
Posted on Dec 18, 2010
My Olympus 1050 SW looks like it might have a little water inside the camera. The lens is foggy. I didn't take it very deep the last time I was in the water with it, but I did store it in a cooler and...
You can TRY and dry out the camera, but I can pretty much guarantee you that there is corrosion inside and it will eventually fail if it hasn't done so already. The Olympus Stylus Tough cameras are not very tough or waterproof unfortunately. I have seen dozens of them with smashed LCD windows or that have leaked water.
Don't buy a waterproof camera, cause they aren't waterproof. Buy an underwater case and put your camera in that.
To try and dry out the camera, some people suggest putting it in a ziplock back with rice to pull out the moisture, it's not a bad thing to try. The fog in the lens MIGHT go away, but it will most likely leave spots or a big ring which will show up on all your pictures.
Your camera is most likely a goner, sorry to say.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Olympus Stylus / mju 1050 SW Digital...
My olympus stylus 6020 is about 5 months old. while trying it out in fresh water, the camera worked initially and then after a couple of pictures turned off and a "reformat memory card' msg came...
Once a week, I climb a mountain and shout for all the world to hear...."the only truly waterproof camera is one in a specially-designed plastic waterproof housing. Any point and shoot camera that says it's waterproof WILL LEAK! You just don't know when."
May 03, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
The description said it was an underwater camera but once i took it underwater it turned off and will not turn on.
Welcome to FixYa.
Before using the camera in under water, you have to secure that battery cover,card slot cover snd DC IN terminal cover are completely closed to prvent water from getting inside the camera and damaging it. Please note that the camera accessories are not waterproof.
Yes, Sanyo VPC-WH1 High Definition Camcorder is a waterproof camcorder, however you can not used it in all types of water. Below are the Cautions concerning use in water.
* The waterproof properties of the camera apply to fresh water and saltwater only. They do not apply to cleaning substances, chemicals or water from spas.
* Do not immerse in water at a depth greater that 3.0m (9.84ft)
* Do not subject the camera to high-pressure water.
* Do not immerse in water for longer than 60 minutes.
After 60 min. of use in water, allow it to dry for at least 10 min.
* Do not immerse in water that is warmer than 40 degree C.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover with wet hands.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover on the beach or at the poolside.
* Do not jolt the camera while it is immersed in water. doing so may cause the battery cover, card slot cover or DC IN terminal cover to open.
And one more thing that you have to do is to chaged/replaced the waterproof seals every year with new ones. For replacing the seals, please consult your dealer and take note that there is a fee for replacing the waterproof seals.
I hope this information will give you an idea on how to use your camera under water.
Feel free to send us your comments and suggestions.
Thank you for using FixYa.
Apr 06, 2011 | Sanyo VPC-WH1 High Definition Camcorder
Waterproof camera seems to not be working since the pool.
The camera is supposed to be waterproof to 10 feet for about an hour if the camera has never been subjected to any bumps or rough treatment. Can you say you followed those guidelines?
Jul 12, 2010 | Olympus Stylus 810 Digital Camera
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
I switch the camera on. I get 3 beeps and it shuts down.
The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again.
Thanks for using fixya
Jul 26, 2009 | Samsung Digimax S600 Digital Camera
When i turn the camera on it chimes 3 times then shuts off
you should have dropped the camrer down at least once. you have to replace the lens array.it costs around 60$.
Jun 04, 2009 | Olympus ? 1030SW Digital Camera
I just posted this answer on an old Dec. 07 posting.
In case you can't find it, try opening the DC IN / USB port cover just to the right of the dial. This breaks the waterproof seal and allows the camera to open. I think the design flaw is an inadequate volume differential in the water sealed cavity to properly account for the change in volume caused by the lens opening / retracting. The USB cover can be closed once the lens is open to restore the waterproof characteristics.
Mar 24, 2008 | Olympus Stylus 710 Digital Camera
Olympus 710 lens won't open
I had the same exact issue. LISTEN UP I CAN FIX THIS. I began disassmbly and removed the outer shell of the camera (after I realized my warranty was no longer valid of course). I found that with the majority of the outer shell removed the lens opened again... Hmm I thought, Curious.
I will cut to the chase. My theory: the "waterproof seals" don't allow for an adequate change in volume within the sealed cavity when the lens is fully opened. You can see the seals going concave and convex as the camera struggles to open the lens. it can't. I am not sure why this issue develops over time. But who cares I have an easy way to fix it.
SOLUTION: Break the seal every time you open your lens. Sounds like a bad solution at first. EXCEPT you can break the seal by simply opening the DC USB port that you would normally open download you pics. So just right of the dial pop open the DC USB cover. Turn on your camera opening the lens and take as many pictures as you want. Also once the lens is out feel free to close the USB port cover to prevent water damage.
PEACE
Dec 01, 2007 | Olympus Stylus 710 Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
181 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
