Question about M-Audio Fast Track USB (FASTTRACK) Audio Input
M-audio fast track sound only coming out of right side
Recording with Acid and I'm only getting sound out of the right side when recording in Stereo. I don't want to record in mono but that's the only thing that gets sound to come out of both sides. Is there a way to fix this? The meter on acid is just picking up signal from the right side too....double-you-tee-eff?? Thanks! - Nick
    Problem Solver:
  • 6 Answers
I havent played with acid a lot... but this is what i can tell you... most of the softwares have configurable inputs... seems like your inputs are configured as stereo input and hence it will pick up the signal from both the left and right discreetly... which means that you would need to feed audio to both the channels for the meter to pump on both bars...The other option is to PAN the track center and not hard left right... this would get audio to both ears of headphone as well as the output meters...
these are basically some of the few things tht will get u sound on both ears and bars...
The bigger question here thoug is why do you want to record in stereo?? and not mono?
Posted on Jul 14, 2009
Headphones-monitoring only on one channel. Only records on one channel in pc
have you check your settings? you mention your recording so please do check your recording settingsif its stereo type...please check also if you play any data it is not a one channel only
Oct 29, 2009 | M-Audio Fast Track External Sound System
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Sound coming through computer speakers instead of through fast track.
Check your audio settings to make sure that it's going to the right driver. goto: start -> control panel -> sound and audio devices out of the 5 tabs, you'll want to pay attention to 2 of them, these are the "audio" and "voice" tabs. Make sure that your speakers on are the external sound system's drivers and not your internal sound card. (Basically, make your sound playback the same as your sound recording)
Feb 17, 2007 | M-Audio Fast Track External Sound System
M-Audio Fast Track USB (FASTTRACK) Audio Input Logo
815 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
