Question about Lanier Office Equipment & Supplies
How do I clean the transfer belt on my Lanier LD232c (same as Ricoh Aficio 2232)?
  • 313 Answers
The transfer belts on these generaly cant be cleaned if you know how you can just remove the transfer belt unit and take the cleaning unit ou this is positioned on teh leaft hand side just under the belt at the top there is screw take this out then press the small brown lever and and pull teh unit out carefully make sure you press the lever in as jif you dont you can damage the belt..vac this out and wipe the blade with a soft dry cloth.. if you are savy with the machine the main area to clean is the alloy or chrome roller at the top.. you will have to take the belt off to clean this.. the id sensors read off this to get reg and colour calibration right so it coulld cause problems if this is dirty..let me know if this helps or if you need more info..Good Luck A
Posted on Jun 29, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How so I clear error code SC 442 on Aficio SP C811DN?
This is a ITB contact motor error.
Check/clean/replace contact sensor.
Replace transfer belt contact motor.
Check harness and connectors to motor and sensor.
Check for mechanical binds.
May 19, 2014 | Ricoh Intermediate Transfer Belt Unit for...
Error message sc.440 on ricoh mp4000 copier
It happen when there is a slight load tansfer belt. What l did was..clean all the rollers & bushings underneath the transfer belt. Threre are 3 rollers..4 bearings & 2 bushings. Remove all stains.. And also you could polish the surface of the transfer belt by using car polish liquid to smoothen the belt rotation
Jun 28, 2013 | Ricoh Aficio Mp5000 Lanier Ld050
I have some ricoh aficio 1224c with errors c481
SC481
Transfer belt mark detection error
• The main motor is operating; and
the lock signal is detected. → The
belt mark sensor signal does not
change for 120 milliseconds.
• Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
I would remove the pcu unit (3 screws)and check the transfer assy belt mark and clean the sensor that reads the belt mark. Worst case senerio is replaceing the entire pcu unit.
Mar 07, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
Eror 471
"transfer belt error"
Turn machine off (unplug), reseat the transfer belt, and try again. If the problem persists, clean or replace sensors, replace the belt, or replace the motor. Check the contact and release mechanism on the transfer belt.
Apr 13, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh color aficio 6513
The following is taken from the service manual I hope it helps Thanks J
SC457 Position error for
the image
transfer belt’s
cleaning unit
- Timing & Condition
• When the belt cleaning
section touches the
image transfer belt, but
the belt cleaning sensor
signal remains LOW.
section releases from the
remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning
shift clutch
• Defective drum
peripheral component
motor
• Defective I/O control
board
• Defective main control
board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning
H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-
012)
4. Replace the belt cleaning shift clutch.
(Output Check: SP5-804-036)
5. Replace the drum peripheral component
motor.
6. Replace the I/O control board.
7. Replace the main control board.
[Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Jan 06, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
330 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
