Question about Compaq Keyboard
Both shift keys not working in my laptop
I tried the following solution but the problem not solved
Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
thanks
WEl Bro I Read Your Problem ITs A Very Complicated Isse So I have a Easy Solution For It The Solution is that Put Your Key BOard in Water OR Through From the Window OR Put it Into Your Dusbin :D
Posted on Jun 29, 2009
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
Shift key not working
Well brother, It's a compatibility problem of hardware configuration with their respective software version.
I brought a Samsung RV509 Model in feb 2013 and after 2 or 3 months it's shift keys and caps lock stopped working.
This problem persist until now But, Now Shift keys and caps lock start working, Due to a Windows Update.
So, Keep updating your pc, This problem can be solved.
Mar 20, 2013 | Samsung RF511 15.6 inch Laptop - Black...
On ma keyboard shift button does not work
Try and reload the motherboard drivers. If this does not work then you must remove the keypads and clean the shift key pads/switch . If this wont solve this can be related to a hardware issue and the cost of a new keypad should be checked.
Try if the key can be swapped from a condemned set.
Jul 25, 2011 | Toshiba Satellite 1400103 PC Notebook
SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 27, 2010 | Acer TravelMate 2480 Notebook
Loading
Try this:
Turn off the computer by holding down the power button. Wait 10 seconds, then press the power button while holding down one of the SHIFT keys. Keep holding down the SHIFT key as your computer starts. This will make it start in Safe Mode, which will do various checks, clear caches, etc. It *may* fix your problem.
** Note: there's a small risk of data loss when reinstalling the operating system. It's important to have backups of your important pictures and other files. **If Safe Mode doesn't solve your problem, locate the system disc that came with your Mac. Put it in the drive and turn the machine off. Turn it back on while holding the C key. Follow the directions to reinstall the operating system.
Good luck and let us know if it worked or not. Please rate me if I helped you solve your problem.
Bot
Jul 06, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Right side shift key too small
its better to use pointer as a shift key
this will solve ur problem and make ur work easy
suppose if you disable pointer key it may cause disturbance or difficulty while typing email or doing some other thing
thank u....................
Jul 29, 2009 | HP 419320-001 - HP Pavilion dv4000 Series...
Where is the ''full stop'' on keyboard of the note book?
On the right hand side of the keyboard, the 3rd key to the left of the Shift key (counting the Shift key as the 1st key) and the comma key is the 4th key to the left of the Shift key.
Mar 06, 2009 | Sony Computers & Internet
Nov 02, 2008 | Compaq Keyboard
Shift key wont work!!!!!
It sounds like you have a FilterKeys options checked that is disabling your Shift keys.
Try going to Start -> Control Panel -> Accessibility Options
Uncheck all boxes in the Keyboard tab (StickKeys, FilterKeys and ToggleKeys) and click Apply or OK.
Try your Shift keys now.
May 08, 2008 | Compaq Evo N610C Notebook
Compaq Keyboard Logo
3,296 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
